Thankyou i will give it ago
Ok so ive had a go and still cant get a connection i have changed the setting to 80 aswell as you suggested with no luck and tripple checked my connections swapped tx and rx several times just incase with no joy
OK, thanks for testing. I’ll try to find some time to do some testing/debugging myself this week.
@janpom i also tried that aswell with no luck ill try anything you put to me no problem thankyou for your help could it be that i am using a mini arduino and not your circuit ?
No, that’s definitely not it. My circuit is basically a barebone Arduino as well. I suppose it’s just that my latest FW update doesn’t really fix things for VESC FW 3.48. I hope to find some time for it tonight. Thanks for the feedback.
@Wainecaplin @Bbaldrickk I have some good news, which however may actually be bad news for you. I just installed the 3.48 on my ESCapes and my Dave with the v0.5 that’s permanently connected immediately stopped working (as expected). Then, however, I connected my other Dave with the FW from the 64b_limit
branch and that one just worked. So I’m afraid the problem must be something at your end.
Make sure your TX/RX wires are correctly connected and that you have your VESCs correctly configured. Fingers crossed. May you see the green square soon.
I’ll soon release DAVEga v0.6, which will be VESC 3.48 compliant (while retaining compatibility with older VESC FWs).
Thankyou i will givw it a try asap
Well it works not sure exactly what happened as all i done was re download last night flashed and it worked straight away.
Nice! I like the color choice for your enclosure. And the buttons are cool as well. Are they printed?
The deck a trucks look familiar.
Hello all,
I’ve just received my screens from aliexpress and tried to install the davega. But the screens keeps beeing white. Can someone please assist me? I’m on the 1.0 hardware received from janpom.
Yeh i hacked and slashed the irdesighn case to fit a 2.2inch screen and to suit my needs
Hi, sorry, I got your message but haven’t had time to respond yet. This is weird since I have tested all boards before shipping. Did the package look like it might have got some beating?
Have you tested if you can update the FW? If not, please try that first. If that works, it’s probably a bad display. If it doesn’t work, the board is probably broken and it’s not worth debugging. I can just send you another one.
Wow, that’s neat! Would you share the stl files with us?
No the package was fine. I’ve ordered 3 display (one was broken), they all display white.
I did try to upload the firmware but still have the issue.
Just to be clear: The FW upload was successful?
Tryied again, i have this error now
Did you install the driver? Did you select the right com port/board? Did you solder/buy the parts yourself?
When you tried installing the FW before, did it work without this error? Please double-check your Arduino IDE settings are correct as @Mich21050 suggests. https://github.com/janpom/davega#configuring-and-installing-firmware
If you can’t get the FW updated, that’s likely a bad board. I believe you have the DIY kit as well, right? Do you think you could try assembling that one and see if you can get it working? That way we would rule out there’s a problem in the display or in the Arduino IDE setup.
Ok i will build the diy kit and keep you posted. Thank you
