I can print you the enclosure and mount the buttons and send it to you if you like, I have all the pieces on my bench. It will take awhile to get to you.
I could print it for you… I still owe you something @mmaner just offering it bc. I’m within the EU…
Yeah i did
Cool, no worries, I can send the buttons if they are difficult to source there.
That’s very nice of you. Thanks for the offer, but shipping from US to EU costs arm and leg. It’s not worth it. I can ask a friend to print it for me.
Could you please just share the link for the correct buttons? I’m sure it’s somewhere in this thread, but I can’t find it. There’s too much stuff already.
Thanks, Michael. I appreciate the offer, but it won’t be necessary.
Sure, here ya go.
100 Pcs GZFY 6x6x4.5mm Panel PCB Momentary Tactile Tact Push Button Switch 4 Pin DIP https://www.amazon.com/dp/B01N6GU7TA/ref=cm_sw_r_cp_apa_i_d5XzCbRX9H3ES
Oh, it’s these? I have a ton of them. Thanks!
I have the green dot! Incase anyone is wondering, i didnt update to the new ACKMANIC firmware (3.xx, I was still 2.54). It will not work on the old firmware (I may have missed this if was already posted in the thread). I installed the new firmware on one vesc, and the DAVEGA connected. I just really didnt want to redo all my settings on the new software, but I guess I am now! The DAVEGA is worth it. I am excited to test it out!
One more thing, sorry for clogging this up… hopefully it will help someone in the future… My speed was off by a factor of 3 (I use mph) 3 mph on the DAVEga is really 9 mph 5 is really 15 8 is really 32 I verified this with gps. It was easy to do the calculations while riding but Im not sure what setting I messed up. I have 97mm wheels, 18t motor pulley, 36t wheel pulley, 7 pair poles Can I just multiply a setting by 3 to get the correct speed and call it done? I will look through the code again tomorrow to see if there is a typo but wanted to out it out here as well.
I bet everything is actually off by a factor of PI since you set the WHEEL_CIRCUMFERENCE_MM
to the wheel diameter. Change the 97 to 305 and you should be good.
Meme time, kind of
Yep, I teach high school math and when I explain this to my students, I either get the look “huh? WTF? That isnt true” or “what a nerd” I just wasnt paying attention when I input that number.
The irony is so rich, perfect to introduce the concept to students, next time they will listen if they can also enjoy the irony
v0.5 released: https://github.com/janpom/davega/releases/tag/v0.5
- configurable text screen
- new text screen items
- MOSFET temperature
- motor temperature
- motor current
- battery current
- duty cycle
- configurable text screen font size
- total km (miles) displayed correctly when greater than 1000
- WHEEL_CIRCUMFERENCE_MM replaced with WHEEL_DIAMETER_MM
- SHOW_AVG_CELL_VOLTAGE is true by default
Plans for future developments:
- battery odometer (total Wh discharged; should be a good indicator of battery health)
- estimated range
- multiple text screens (there’s already too many items to fit on one screen, especially with horizontal layout)
Any other feature requests?
Stopwatch feature would be cool if possible? For clocking lap times or total ride time
Ride time is already available. Lap times? Really?
So by feature requests you meant only if you like them too? Got it thanks
