I tried that and I don’t think that would work well. The enclosure angle is greater than the board tip angle so if you flip it the display is facing slightly away from the rider. It looks weird and I think reflections would be a problem.
The enclosure is actually a great fit for the board tail since the tip there is angled slightly down. I guess I’ll just have to learn riding backwards.
Any of you guys in the USA have an extra screen you want to sell me. Fucking stepped on my only 2 inch screen. I have a ton of 2.2" ones but they won’t fit in my @lrdesigns enclosure.
Edit: I said fuck it and ordered from ALi. Paid twice as much as the screens for faster shipping. I seriously can’t be out my DAVega’s. I need them now.
I finally found some time and energy to do more developments. I added more items to the text screen.
MOSFET temperature
motor temperature
motor current
battery current
duty cycle
I originally only wanted to add the motor temperature as per a request from @JonathanLau1983, but since I was already at it I thought I could just as well add a little more stuff since it was pretty straightforward.
Note that you have to have the motor NTC connected to the VESC, otherwise you’ll get rubbish negative numbers for the motor temperature (as shown at the picture ).
Temperatures are in Fahrenheit when imperial units are on.
Since there’s already more items than the text screen can accommodate, you can now configure which ones you want to see. Here’s the relevant excerpt from the config (mind the trailing backslashes, which are mandatory):
// Information to be displayed on the text screen. Only relevant if TEXT_SCREEN_ENABLED is set.
// Available options:
// TSCR_FW_VERSION
// TSCR_MOSFET_TEMPERATURE
// TSCR_MOTOR_TEMPERATURE
// TSCR_MOTOR_CURRENT
// TSCR_BATTERY_CURRENT
// TSCR_DUTY_CYCLE
// TSCR_TOTAL_VOLTAGE
// TSCR_MIN_TOTAL_VOLTAGE
// TSCR_AVG_CELL_VOLTAGE
// TSCR_BATTERY_CAPACITY_MAH
// TSCR_BATTERY_CAPACITY_PERCENT
// TSCR_TRIP_DISTANCE
// TSCR_TOTAL_DISTANCE
// TSCR_SPEED
// TSCR_MAX_SPEED
// TSCR_AVG_SPEED
// TSCR_TIME_ELAPSED
// TSCR_TIME_RIDING
// TSCR_FAULT_CODE
#define TEXT_SCREEN_ITEMS { \
TSCR_TOTAL_VOLTAGE, \
TSCR_MIN_TOTAL_VOLTAGE, \
TSCR_AVG_CELL_VOLTAGE, \
TSCR_BATTERY_CAPACITY_MAH, \
TSCR_BATTERY_CAPACITY_PERCENT, \
TSCR_TRIP_DISTANCE, \
TSCR_TOTAL_DISTANCE, \
TSCR_SPEED, \
TSCR_MAX_SPEED, \
TSCR_AVG_SPEED, \
TSCR_TIME_RIDING, \
TSCR_FAULT_CODE, \
I believe that someone (@lrdesigns?) has asked for a bigger font. There’s now an option for that as well (though I would call it rather experimental ). It’s only recommended for the horizontal layout. Note that some items may overflow the right border. It’s easy to adjust (shorten) the labels in the code (davega_text_screen.cpp). I may move the labels to the config at some point if there’s interest.
The construction industry is holding us back. Engineering is already almost totally metric or at least metric-friendly. Most of the construction workers, especially union ones, would rather break into your house at night and murder you, rather than be told what a millimeter is.
We have huge home improvement stores here called “Home Depot” and “Menards” and they think metric is some sort of joke. I went to buy a tape measure and they had 80+ different models – not a single one had metric on it. I had to tell them to eat my shit and ordered one online right in front of them. If they go out of business, we will know why and I won’t feel bad for them.
