That would be helpful, so that we know whether the problem is somewhere in Dave or it’s just an incompatibility with Ackmaniac’s FW.
I hadn’t thought about that, I default use Acks firmware. That’s likely the cause.
On another note… I’ve ordered a ton of filiment. Next week I’m gonna print housings for a few days for people that need them.
I’m using ack’s firmware (latest whatever that is) and it was working. I’ll do some testing in a few minutes just to verify.
Every screen I seem to order doesn’t work right. I have to pinch the screen for them to work properly. Even picked up some nano’s yesterday just to test and I get the same screen flickering.
@mmaner I would like to buy a case from you if possible.
I just ordered 5kg of pteg filament as well and can help out if needed. I also have the dremel laser cutter coming soon, and can cut some cases if someone wants to create a file for me
No buying, just pay shipping. I’ll start printing Tuesday.
Hm, are you talking about GitHub - Ackmaniac/bldc: The code for my custom BLDC controller.? Or are there any other FW mods? That repo is a bit strange. There are not many changes. It doesn’t seem to be in sync with the latest Vedder’s updates. There are no releases and I can see no other versions than 3.101 and 3.102. Where do you get the 3.54 and 4.02 from?
I fat fingered it, driving. Sorry about that. It’s 2.54 and 3.102.
DAVEga FW v0.2 released: https://github.com/janpom/davega/releases/tag/v0.2
BTW, you want the davega-v0.2.zip
file, not the sources (unless you know what you’re doing).
Switches have arrived, they’re pretty small.
Enclosure is still work in progress, need to add bolt slots for attaching to board etc.
Looking mint😎
Nice! You’re the first to have the v0.3!
What are those switches for?
Going to hook up to Buttons 1 and 2. More of a futureproof thing. Future firmware could use them to toggle things, maybe imperial to metric etc.
Oh ok, it should look great, have you 3d printed that case?
Note that button 2 is already used in FW v0.2. It resets the mAh. Button 3 will be used for toggling between multiple screens. Coming soon.
Can’t wait to put mine together
What buttons have you guys been going for?
