Yes you can.
What size is the bms height and length widget? Is it charge only?
@Deckoz I’ve been patiently waiting for this. Happy to see you’re moving forward with the build!
What bearings did you need to order for the trampa hubs to fit on the 10mm SZ axles?
Mr @Deckoz can you open the YouTube permissions a bit to allow me the awesomeness in Ireland? I use 4 different Vpns for work and like to keep that just for work lol
Thank you kindly
I think it might be the song on a couple videos Griz and Big Gigantic aren’t able to be played there I don’t think?
Edit: actually all the videos in this thread got deleted @banjaxxed I’ll reupload some
Epic! Sounds like an instrumental of The Doors - Alabama Song.
I wonder if I could copy all this hard work by laying fibre over a cheap two filter respirator
Then pop the mask out and fit two
That’s probably not a half bad Idea and would probably work. I’m sure you could get something put together nice
I love me some Doors. But the song is
You’re a bloody genius! Getting speakers on a board is one thing, making it functional and sound amazing is something else! Great work bro
very nice … great idea
So it’s about to feel like Christmas up in here.
In transit
- Acid yellow Pass
- Gear Drive for the Evo
- Rest of the parts for the Trampa
- New set of surfrodz for this build
- And most importantly the Gummies for this build
Last piece I need to order is @psychotiller mounts and possibly 90mm axles depending on the where the pulleys sit. So that’s TBD once the gummies and new SurfRodZ show up.
Also thanks to @anorak234 and @Namasaki for updating the OP with the current build specs.
I know y’all probably aren’t as excited as I am. But 6 months after having the idea for this build and waiting for parts to be made, and seeing this finally start to come together as a whole is
If it’s surf rodz axles you are looking for, I got you. I have a box of 90mm axles, I’ll send you 2 sets (x8). PM me an address.
You should have it. I’ll pm ya in a bit. Thanks bro.
12mm pulleys = 80mm axles with 2.5 or 3 spacers.
@psychotiller my Jenso Superstar pulleys are 18mm.
The gummies are only 50mm wide… so 25mm to center of hub. I could probably measure 107s to the center… Either way I’ve never seen superstars on surfrodz so having some trouble envisioning the spacing without mocking up. Maybe you have relative measurements for your six shooters. But likely it will need 90mm axles I’m guessing.
So 90’s it is!! We can switch sixshooters straight to abec 107s without spacer changes.
Cool that’s what I thought, thanks man!
