it looks preety sharp to me, ive cut myself open a few time just on jessup grip tape which is one of the finest (fine) grip tapes…
you think you could make a deck like an evolve gtx? and making room in the wood for battery+esc? and in the areas that i marked i want it to be full and not cut…
This would be a great idea! If enough forethought went into it, it might be a popular new way to upgrade them, just like the 10s4/5p mods.
I wonder what gtx /gt users would want changed about their decks
I read a lot of post by people with the gt\x and it was almost about the same thing, the battery! too small, no room to upgrade… people want more range to their boards. more range=more fun except that I don’t think it needs any other upgrade…
You mean a Top Mount? Interesting.
Simple 3D print enclosure riser upgrades (10mm, 14mm, 18mm or 20mm) on Bamboo GT decks are popular in order to fit 18650 Li-ion batts. Also some 22mm Heat Sink risers to lower VESC and BMS and allowing larger full lenght enclosure fitting batteries.
Yeah I would easily be able to create something like what you said, the battery and esc recess would only be able to be around 9mm though @Bardakon
Tipped deck option would be interested, especially with a CF bottom layer.
If you match the Tramp deck then current enclosures could be used, also concave would be welcome
Would be happy to be a test dummy, in Ireland so no ship woes
All depends what people would want bro. I’d make a custom deck to what people want, if someone say wanted a loaded vanguard shape then I’d make it once they’ve paid for it and there own specs
I’ll work it out, didn’t consider it till today, I need to work out how far forward I could move the rear trucks
Edit: I wonder if Bajaboard @BajaAle ever had a prototype with a tail ?
Ok sure. Just draw up some design. It says he’s last seen in Feb
It’s just vinyl sticker to make it look like CF
I will be looking to actually cover some boards in CF material with a resin on top once a few boards are sold @briman05
Yes as you said before but at first they would be vinyl. How many plys are these decks.
Just managed to finish building a mini portable deck. Painted it black to make it look stealthy. No concaves or anything in this deck as I just wanted to keep it simple as I’ll be using it while going abroad. As you all asked me to build one first then show you lot here’s some photos of it !
DM me to discuss deck styles and I can start building them within a week.
That deck is flatter than Kate Hudson my friend.
It needs gas pedals or we’ll all die.
