I just got my motor, pulleys, mount and trucks from Enertion / @onloop. But I’m slightly confused with the different truck size, they are not the same.
Which one would the motor go on, the one with the longer axle (short hanger) or the shorter axle (long hanger)?
I’m building a single motor board, so one of the rear wheels has no pulley, that doesn’t seem to fit well…on the short axle truck, the nut barely secures is. On the long axle, the nut is tightened, but the wheel is not secure at all. What am I doing wrong here?
Pictures please! I haven’t used Enertion’s trucks, but I’d assume one of the trucks comes with 2 long axles and the the other trucks come with regular axle?
the motors go on the truck with the longer axles because the pulleys have a bearing on them that fits on.
if you are only making single motor you may need to throw a spacer in.
