Just got a 2nd one. Good job, love all the updates, they’re great.
Sorry to keep bugging with feature request - Would it be possible to have a trip playback mode on the website (e.g. you hit play on the website, and it plays back on the timeline instead of having to drag the cursor over it)? The purpose would be for making esk8 videos - it would be easy to line up time stamps on videos so I can edit in a recorded trip as an overlay.
• Battery Tile. The value is calculated based on your VESC limits and current voltage. Please make sure you set Maximum input voltage to the voltage that your battery has when fully charged and Battery cutoff end to the voltage when it has no charge left.
• You can now turn on Notifications. Imagine the app is running in the background, display is off and the phone is in your pocket. Suddenly Bluetooth disconnects or even worse VESC fault happens. You will get a notification which will make a usual sound and/or vibrate.
• Added possibility not to upload location data but still use GPS for distance and speed calculation
• Small speed and memory optimizations for iOS which should hopefully help older devices to keep the app running in the background and not being killed.
for some reason it is not reading vesc2, it reads 1 just fine. both motors spin up and have the correct settings. any idea why the second isnt working - it says connection failed.
never mind, I changed the controller ID to 0 for VESC2 which is the same as VESC1 and it worked. I tested both VESCs and they had the correct detection settings for each motor.
I am currently working on the video overlay. I want to make it beautiful, easy to use, customizable and more importantly allow to use the footage from any recording device, not just mobile (think about GoPro and similar).
@monkey32 That won’t be a problem. You can double check the number of pins on the UART port. I did a simple how-to guide https://metr.at/setup to help with the initial setup. As you can see in step 4 I am using VESC 4.10 myself.
