If the record was already stopped, there is a very little chance it was lost. I think it should be there, you can also navigate with file browser and find it manually (each record has 2 files *.r and *.s extensions)
Today I borrowed Android 8 and tested location fix which seems to work fine in the latest version (2.2.64)
Thank you everyone for finding bugs, please remember it is always more helpful when you send along your log file
@rpasichnyk now I can confirm that everything is back to normal after the latest update, both VESC’s detected, GPS perfectly in sync with the rest of the data
Thanks
Also I liked the new record upload popup, sometimes I wasn’t sure if the record was indeed being sent, some longer rides take a while to finish
Hi I made it to fully work in 8.1, nothing special but that’s what I did,
Fresh clean downgrade to 7.1.1, set up all my apps metr included and was working perfect, but accidentally I install the 8.1 OTA
Curious was the app still remember the module from the 7.1, I did not search again for the module it was there, and did connect without any problems and data is going up and down!!
Now I have the goodness of 8.1 with metr in my one plus 5t!
This is expected behavior. You probably didn’t notice that records on top are marked as “Favorites”. I agree that might be hard to see, I should make it more obvious.
I asked this on another app thread, do you know how easy this would be to add support for the Fitbit Ionic? Looks like it accepts javascript, css, and svg languages.
for some reason the data got corrupted and firmware version was detected as 0.0, which in turn resulted in using old command codes (for 2.x) firmware and completely messed up Realtime Data. I will try to provide a fix soon!
Hey so I got the module tonight and did the wire switching and modified the connector to fit the VESC6 one - I just want to double check before giving it power does this all look right to you?
Thank you everyone and sorry for the latest couple updates that had issues. The reason for this is that huge amount of code has been merged into the master branch in the preparation for something really really cool. I wanted to make sure all the existing functionality remains intact which seems like the case after hot fixes. Most of the changes are done under the hood and not visible… for now
