I’m donating two injection molds to this esk8 community
Pulley specs
5mm Pitch HTD belts
9mm wide & 12mm Wide
Integrated flanged 608 bearing
Conditions of use
Exclusively for use by community members.
Access via community organized group buys only.
Managed by Level 3 members only.
This offer is not intended for commercial resellers.
There will be a MOQ to start production.
For more details PM me.
The design incorporates a flanged bearing & is compatible with Abec Flywheels & Wheels with Similar core pattern. Compatible only with trucks that have extended axles (need 7mm longer axle to accommodate bearing)
Despite how awesome this is, a bit sad to not see 15mm wide, but still… that’d be asking too much if they never existed to begin with. Lots of 12mm builds out there and I’m sure this will be put to good use. I hope so at least these look fresh!
That’s great. I think 15mm with the bearings would be our bread and butter.
15mm pulleys would also work with 9mm and 12mm belts just fine if needed. Will also help to narrow this down to 1 part, which I think will help get a higher quantity group buy.
If we can get these down to a reasonable price they would be the go to option for a lot of builds
