Hey @sayekim, It will work with fatboy 36t or larger, not sure about 32t would need to double check. The distance between the plates is 168mm. I dont know what the distance is on those januax is?
@XTLA i think so, just a little more complicated manage. I can ask them to not do the last few steps to do the holes. My original plan with the first round was to have an option for other or no hole options for people who want to make their own motor plates or a different plates. But everyone wanted marc88 plate holes. Its not hard to drill your own holes and tap them.
Hit up @psychotiller. He has a press fit mount for the 176mm hanger that works perfectly. There might be quite a few riders out there with 176mm hangers because of the SR Fall Specials (that they are still offering BTW).
hey guys - just a warn. Today i was press-fitting the adaptor do the SR hangar (bullet 3 on installation guide). I overtighned the axle (as it was still missing 1mm to go in) and end up damaging the hanger inner threads and the axle .
Using the axles to press fit the adapter is fine as long as you don’t try to get rid of that tiny gap between the adapter and the hangar. AFAIK neither me nor @Winfly nor @sofu were able to close that gap using the axle to press it in.
