Inspired by @Deckoz ‘Master Evo’ ‘Clone’ makes sense
Starting my build thread to help me keep track of the last parts - attempting to wait until I have everything in one big exquisite pile
Waiting for the enclosure but looks like a 13s5p is possible
the lovely red FocBox case is going on top
- LANDYACHTZ Evo 36 Falcon 2018 http://www.hungryhills.de/longboard/decks/22537/landyachtz-evo-36-falcon-2018-longboard-deck
- eBoosted Evo Falcon Enc. (and rubber gasket) @Eboosted http://eboardsperu.com/product/landyachtz-evo-falcon-enclosure/
- Enertion Nano-X Controller http://www.enertionboards.com/electric-skateboard-parts/nano-x-enertion-2-4ghz-controller/
- FOCBOX Motor Controller http://www.enertionboards.com/FOCBOX-speed-controller.html
- 3.5mm Gold Male Bullet to 4.0mm Female Bullet Adapter Amazon.co.uk
- Canbus for FoxBox https://psychotiller.com/product/canbus-connection
- Red Dual FocBox Case with Cooling Fins https://shop.3dservisas.eu/collections/cases/products/limited-edition-red-dual-focbox-case-with-cooling-fins-v2
- Red FocBox Case mount https://shop.3dservisas.eu/collections/cases/products/limited-edition-red-dual-focbox-case-mounting-plate-for-trampa-mbs-longboard-trucks
- TorqueBoards v2 218mm Trucks collections/featured-items/products/torqueboards-218mm-trucks
- TorqueBoards 63mm Motor Mounts collections/electric-skateboard-motor-mounts/products/single-bolt-on-motor-mount-set-only-black
- TorqueBoards 36T 12mm HTD5 Wheel Pulley collections/electric-skateboard-pulley-belt-combo-kits/products/36t-abec-pulley-15mm-combo-kit
- TorqueBoards 265mm Timing Belts HTD5 12mm products/280mm-htd5-12mm-4x-belt-bundle
- Turnigy Aerodrive SK3 6374 (192KV 8mm Shaft 4.0mm Bullet) https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6374-192kv-brushless-outrunner-motor.html
- Metr Pro Bluetooth https://metr.at/shop28
- Anti-Spark Swtich @Martinsp http://electricskateboard.repair/index.php?id_product=36&controller=product
- Thermopeanut (Enc. Temp Monitor) Spotpris el – Få det billigt: elpris idag | SENSE
- Bronson G3 Bearings Amazon.co.uk
- 13s5p Samsung 30Q Samsung 30Q | Fogstar Wholesale
- Volt Meter @rey8801
- M4 Anodized Countersinks @rey8801
- Bolzen 6° Rubber Wedge Riser Pads Amazon.de
- Dooks Short Stack Riser Pads 1/4" Page Not Found! Warehouse Skateboards has moved that page.
- Sabre Barrel Bushings 90a Sabre Longboard Bushings (barrel) - Choose Durometer
- Sabre Barrel Bushings 93a Sabre Longboard Bushings (barrel) - Choose Durometer
- Neoprene Stripping with adhesive 2.5 cm width, 13 mm thick Amazon.co.uk
- Plasti-Kote Amazon.co.uk
- BMS https://www.ebay.co.uk/itm/48V-54-6V-13S-18650-Li-ion-Lipolymer-battery-BMS-PCB-PCM-for-ebike- ebicycle-CE-/292203388522?oid=123076268669
- Arduino Spot Weld + case etc. DIY Arduino Battery Spot Welder Prebuilt Kit V4 - Malectrics
- Spot Weld Battery https://hobbyking.com/en_us/turnigy-battery-nano-tech-5000mah-3s-65-130c-lipo-pack-xt-90.html
- Spot Weld Cable DIY Arduino Battery Spot Welder Welding Cable Set - Malectrics
- Spot Weld Foot Switch DIY Arduino Battery Spot Welder Foot Switch - Malectrics
- Spot Weld Fuse DIY Arduino Battery Spot Welder 300A Fuse - Malectrics
- Fuse Case Arduino Spot Welder ANL Fuse Case Kit - Malectrics
- Weld Case Arduino Spot Welder V3 Case Kit - Malectrics
- Kapton Tape Amazon.co.uk
- Tesa 51608 PET Fleece Fabric Tape Amazon.co.uk
- 14 AWG Silicone Wire Amazon.co.uk
- A4 Foam Sheets Amazon.co.uk
- XT-60 Connectors Amazon.co.uk
- Fish paper rings https://www.ebay.co.uk/itm/Red-Insulator-Ring-Terminal-Covers-Adhesive-Paper-For-LI-ION-18650-Cell-Battery/123113718847?ssPageName=STRK%3AMEBIDX%3AIT&var=423527258687&_trksid=p2057872.m2749.l2649
- Fish paper flat adhesive https://eu.banggood.com/Wholesale-Warehouse-8Pcs-DIY-Red-Fish-Adhesive-Paper-For-Electrical-18650-Battery-Insulating-Cover-wp-Eu-1124133.html
- Nickel Strip 12mm x 0.15mm 12x0.15 40A 12mm x 0.15mm 115m 1800g 1.8kg Solid Pure Nickel Strip Spot Welding 12x0.15 40A | eBay
- Charger (5A for 48V) https://www.ebay.com/itm/Lithium-Battery-Charger-5A-Fast-Charger-for-48V-Li-ion-Li-Po-/401411865792?oid=282935128995
- Charger to Battery Connection (SP13 IP68) Amazon.co.uk
- Custom wheel pattern using water slide decal paper Amazon.co.uk
- Cell Holders https://shop.3dservisas.eu/collections/pcb/products/14-pcs-of-18650-3-4-cell-pcb-holder
- X Washers @akhlut
- XT90s Amazon.co.uk
- Bolzen Big Bolts 2" 2.5" 3" http://www.mantis-longboardshop.de/Montage-Hardware/Mounting-Screws/Bolzen-Bolts-Phillips-1-1-25-1-75-2-2-5-3::86610.html?language=en
