@Grozniy I have a similar set but these allow so much more torque, I had a grub screw that would not move, bent my alien hex, and the standard length ones just didnt work out
and added a little epoxy to keep them from spinning (next time I’m using those screw in ones lol)
i do kinda dig the Frankenstein styling (temporary until I re-grip)
while I wait for that to cure finally getting round to adding the flat-spots on the SK3s
all done
first problem I’ve had to far, I’ve noticed one of the motors has a shaft and can that move about 1mm when its mounted its really noticeable - I checked the visible screws and nothing seems loose is it safe to use like that?
@sk8l8r what’s your motor clearance like against the enclosure at full lean on those TB mounts? I just cant find a mount that will allow me to mount inwards and handle any kind of lean at all.
@brenternet its not bad when using a 12 deg wedge, I’ll take some pics at full lean
@Deckoz thanks, its beginning to drive me nuts not having ridden it yet… lol
@PatRocks cool, I must admit I’m going to use it anyway just worried it will slacken more. I’m pretty sure circlip moves I checked all the screws I could find nothing was slack
I’d appreciate that thank you. I’ve got a riptide cable riser which is 1/2" to use on it but I think I’ll have to skip that for a wedge to get the elevation.
I must admit I think its the wedge that makes this workable I have a 1/2" I can try out see how it works what I want to use is 12 deg wedge and a small 1/4" foam / plastic riser to remove vibration - this seems to work well at stationary not tried anything moving yet - I did decide not to de-wedge the front I really didnt like the instability de-wedging created - noticeable even standing still
well today wasn’t wasted managed to time it right to try out @3DServisas push on ABEC pulleys - I’m so happy I refused to drill cores out to fit those TB screws in ones I have
Progress
had to give up on my red bolts just a little too short using the 10mm neoprene foam
semi final mounting
reasonable clearance
wanted a little extra height on the focbox case, so used an x-washer
gives it more of a spoiler look. I ended up using 12deg wedge and thin Dooks short stack on the back and only a thick Dooks short stark on the front - feels really stable, I tried with the 6deg wedge and when I stood on the front of the board with slack truck bolts felt like balancing on a wire
still to make the cables look nice
@brenternet at full lean (trucks far looser than I would ride with) they don’t touch it just looks that way due to reflection I’ve tried to make them touch and could’nt
other direction
need to work out something to protect my power cables or get a stand
Looking awesome, it’s close but workable. I decided against wedging and I’m going to mount out the back, still got short mounts on the way too so that I can experiment.
Forgot to say just could not fit the switch in the end - just not enough space was looking for a low profile replacement but @Martinsp just released a push on with auto off function, going
to use without switch on 5min auto off (will have access to pull the x90 from battery if needed)
