Doesn’t seem like much of an issue. Have you tried using it? Could be a bearing rocking back and forth when you apply pressure? Perhaps someone else has any advice.
Yeah, just don’t want to bust a brand new motor :b
It has a very different sound than the other one, which runs super smooth.
Do I have your blessing to try it out?
@torqueboards - Finally got around to installing and testing this.
Works fine, but the ‘clicking’ is still there after a few miles ridden. However, it seems at full blast I get quite a bit of (in lack of a better term) ‘torquesteer’ ? Sorta feels like it pulls to a side… I immidiately let go the trigger, because falling at full speed isn’t really a hobby I wanna take up right now
Is there anything I can do to combat this? Maybe the KV is different? Or Max RPM is different? Any insight would be greatly appreciated
The wrong way! the top part of the shaft is thicker than the clip socket, that’s why there is a special plier to spread the clip over the lower side of the shaft. So yeah, all the ways lead to Rome! I did both ways
(oh and speed is wrong, was only going like 38km/h)
This is at speed, going from 75% acceleration to 85-100%
Very weird. At full throttle it even says it’s braking?
Please help Obi Wan @torqueboards, you are my only hope!
PS; Clicking is still there. When rocking the can sideways (yes, sideways, not in-and-out), it actually moves quite a bit. How to fix??
Edit: I have since gone over all connections, taken the motor apart, with no change. Still wiggles, and still can’t pull the same amps as the other one.
Seems like a defective motor
