Your outta control.
Nah man!
To know what is best, you have to try it all, right?
is that motor mount bent?
No, just weird angle.
OOh, and the motor pulley is just sitting there, it is crooked creating the illusion. I still need to loctite it down
Those motor mount arms are tough as nails.
Don’t worry @akhlut, I won’t tell @psychotiller you said he is making bent mounts to purposely sabotage people.
I will keep it between us
i was gonna say they shouldn’t be bent unless you hit something. and if they did bend it should be toward the wheel and not away. just a strange angle.
nah. shit happens. ive bent motor mounts before.
I know! Just playin!
is all good brotha!
Had to drop the pics here too.
Now if it would only stop raining so I can try out the @MoeStooge wheels!
I am running 18/42 on the 120mm wheels.
Settings I am starting with (per VESC):
Motor max: 100amps Motor min: -65 amps
Battery max: 55 amps Battery min: -20amps
10s6p 30q. 200kv @psychotiller 6369 Powerplants.
She is so damn pretty now, I almost don’t want to step on the deck…
Almost.
That deck is awesome looking good job
Beauty and Beast… a Beautiful Badass for sure! Please, did you make a grip tutorial somewhere Tim ? Thanks
How wide are those surfrodz end to end?
200mm
10char
With 80mm axles? So 360mm axle end to axle end (excluding shoulder bolt head)?
Close to that
This has got to be the sexiest build in existence.
