Hey everyone,
So I am the middle of researching getting my own AT board. I think I’ll go with a FOCBOX Unity, and have already lined up buying a 12S5P Eskating.eu battery, enclosure and landy evo.
I am having trouble finding which drivetrain & wheels to go with. I didn’t expect options like trampa to cost more than all of the components I have combined, so i was wondering what other options I have.
I have explored:
Trampa super stars + thier dual motors (Something like £1000)
Eskating.eu MBS stuff + dual motors (Also close to £1000)
Sixshooters + Surfrods, which was £600 without any motors or drivetrain looked into at all
I am actually really happy with these http://www.diyeboard.com/6-15050mm-70a-airless-allterrain-wheels-with-hubs-pulleys-p-587.html, and use them with my current diyeboard landy setup. I know the trucks and motors which come with this set are crappy, so I was wondering where I can get trucks and motor mounts/motors that fit these wheels, if anyone knows. I have seen people use these wheels here in the past, but can’t find the threads now.
Ideally, I don’t want to spend so much on just the wheels and trucks / drivetrain. Please give me recommendations on what to do
I have been talking to him on email and he is making loads of custom stuff - he is living Taiwan atm so it would mean overseas shipping. But he does supply drawings of the Wheel pulley so you can make your own
if ur not 100% committed to this build yet i would consider Kug3lis or Jens drive system, especially for tht kind of cash. as for the motors APS is the way to go when ur not in the states (IMO)
i would skip out on the airless tires as there is numerous post here about the centrifugal force while riding causing those tires to separate from the rim
The brutus setup looks like a possibility. 880$ and it should come with all the wheels and trucks too, this is more what i was looking for for sure. Thanks for the recommendation, I’ll seriously consider this!
TB218 + four 6x2 tires + two vex robotics versa pulley + two 3Dprinted adapter going to cost you ~ $100. Including shipping
Setup would be something like this
Hey @moon I’ve been doing some kingpin research, my calipers say the smooth part of the bolt needs to be 9.2mm diameter for a smooth slop-free fitment, yet the axle bolts on AliExpress have the smooth part at 10mm which of course is what is wanted for the axles.
Can anyone confirm aftermarket bolt fitment? Grade 8 I know
Also length recommendations with riptide bushings?
Alrighty, thanks, maybe edit post #6 above to avoid any future
10mm smooth part of the bolt will not slide through the kingpin hole in the baseplate, on a good days the max there is 9.5mm at the very most, but suspect 9.2mm.
So far I am stuck with going back to sickboards for genuine kingpin bolts.
I appreciate the info. on the aftermarket bolts, they should work and are super cheaper
@mmaner thanks we are talking about SR parts, fark it I’ll head off here again
