There is an option for li ion, i built a pack with it recently
The question is just if the 13s he ordered would work with 12s too
ohhh, that i have no idea
Would this be suitable?
I believe this is the oem. They can supposedly be reconfigured for number of cells in series by jumping some solder pads and changing software settings. I tried this on one and no luck for me.
There’s also an external display…
I checked both links and both offer the 12s only for lifepo4. @Andy87, sounds like each of us will have his challenge. You make yours work with li-ion. I make mine work with 12s. Seems like a lot of fun to be had for 40 bucks.
I asked the producer before I ordered and they said I just need to write them when I placed the order and they will sent it for LiIon set up. I asked after they sent and they said they sent the right type. Let’s hope it is like this but AliExpress… you never know what you get
@Andy87 Have you used your smart BMS yet? Does it work for you? I received mine about a week ago. Of course it’s 13S, even though the seller told me they would send 12S. Fortunately, I figured it can be easily configured for 12S. It’s a matter of shorting the BC3 and BC4 pins and configuring 12 cells using the PC app they provide. The seller even responded to my email and confirmed this is the right way to do it.
I’m still having some issues though. First, when I connect it to the computer and read the cell voltages in the PC app, the first cell is very flaky. It’s exactly the same problem as what’s shown in this video, so I assume it’s a bug.
I also tried connecting the BMS to my Android tablet using the Bluetooth module and that worked fine. However, I’m getting completely wrong cell voltages there. The first two cells appear as dead (around 0.5V) and the third cell voltage is flaky in the same way as the first cell in the PC app. The remaining 9 voltages look OK.
So the software seems buggy. I wonder if the MCU reads correct voltages and it only incorrectly communicates them to the computer/phone or if it has wrong voltages as well – that wouldn’t be good for cell balancing.
I had a similar experience with one there I reconfigured the series count.
But I have multiple other units, unmodified, that work as expected.
Unfortunately I didn’t have had a time before Christmas. Broken motors etc. took more time than expected. As soon as I have the bms installed i‘ll give you a Feedback
@deucesdown Thanks for the info. Have you played with the UART connection to the BMS? I wasn’t able to get it working with Arduino.
I’ve not had a go yet, as the janky apps work well enough for me (barely).
But hey I’ve been thinking about that link you sent to Luuke’s stuff, with the isolated ac-dc 5v buck converters and TP4056 modules. I ordered up a bunch of stuff. I’m thinking, per channel, put in a voltmeter, TP4056 and a 5v dc-dc converter.
voltmeter something like this (There are 2 wire and 3 wire versions, and versions with a calibration pot. Gotta find one that has the required voltage range and has 2 digits precision):
This scary isolated buck converter running off mains voltage
And TP4056 modules. There are 3amp versions, also scary! I think 3 TP4056 in parallel, how is termination handled? (shoutout to @Hummie I think you found these first)
Hm or this, TP5000, 2A, includes heat sink. More likely to work than the 3A one.
Oo three amps. Nice find. Unfortunately someone said hooking 12 of these up to the battery to charge and balance at the same time would cause a short. Damn I want to do that. Who can tell me that’s a bad idea again @Blasto. Who else knows electronics? Maybe could add something extra?
If all the cells are inside a pack, you’ll need an isolated power supply for each.
you made me go through my old shit, this is what i found lol
I linked the isolated power supplies, under $2 per piece.
Im getting conflicting answers. Maybe linear supply vs switching?
You’ve seen this?
Isolated ac-dc 5v supplies, one per TP4056 charger.
It’s been done. It’s just crazy I want one too.
This guy used a separate supply for each module. Hoping @Blasto explains how his buddy uses one supply for multiple. Smaller cheaper.
The cells are individual, not in a “pack”
Aha. Of course. Bummer. So need a supply for each cell. As said
