See if you can find the extended axle original caliber trucks in EU. That will work if you use 2X6355 motors. For 2X6374 motors you need TB218.
You can definitely take a hacksaw the cut the hangar a little bit. Just measure the wheels from outside of one bearing to outside of the other and decide how much of the hangar you might want to remove.
Which adapter did you print, do you have a pic? I updated the design to improve strength and bolt head clearance.
@willumpie82 To me the wobble is totally coming from the motion of the trucks. Probably because you are hitting the natural frequency of your trucks at certain speed. It’s absolutely not an issue.
Cut of some hangar is sure one of the solution. I already think about that option. But I have another one. Cut of some axle and cut new thread. Axle is 8mm so i can cut m8 thread on it. If I leave 10mm of axle and make new spacer with outh diameter of 10mm and m8 hole I can screw wheel with m8 bolt on axle…I have to take some time to figure it out. One is for shure I dont want to pay extra 100€ for trucks.
I printed this adapter.
I bought the 11” trucks from him, fits fine, maybe just a little to long of an axle bit noting that cant be solves with washers and maybe i’ll be replacing the bushings with named brand ones, they squeek a little
So i got these printed out but i need info on what kind of trucks to use on these. What width of trucks do i need to use these…will 210mm trucks fron diy electric skateboard be ok for these? I want to use these bad!!
So ill go ahead and order there duel motor mechanical kit as well. Could use the mounts as well. Thanks again i must have skiped that part going into just printing the big gear
I don’t mind buying the dual motor kit with 218 trucks. I just wanted to make sure of my options. I already got a vruzend battery kit I plan to use on this thing. I want something similar to an evolve gt with the 20 mile range and a 25 mph speed.
