hey folks.
I know that you can flash the VESC using a st232 programmer, but can you also change the settings using the pins on the VESC using the VESC tool?
im asking because my USB port broke off and i am absolutly not able to solder these tiny pins back on.
There is also a third (tricky) method :
Use a specific BLE module, flash it with Vedder’s code through STLink and use VESC Tool (linux only) wirelessly.
This is a beta and a pretty new feature.
More info here : https://vesc-project.com/node/234
