I dont care about the Watts the say
Yeah forget about wattage limitations just run the motors at 12s 100a.
And I will be running gear drives.
Nice man but I’d be careful with going over wattage. ad-least don’t go over current limits.
If you check the actual spec it says 3000, also I’ve seen some test results on this forum that indicate the max was 3000w under load.
