Hey @gigoy, there are a couple of things you can do. I took a quick look at the Wheel lift thread and yes, you have well exceeded the recommended compression of virtually any bushing on the market.
If you have read any of this thread you understand that symmetrical setups are inherently less stable than split setups. Are you open to changing your rear truck by dewedging it or replacing the rear base plate with a Caliber 44?
We do not make them to remove but if you are careful, needle nose pliers of nn vice grips can do the trick, you need to have a light touch and be patient. Compressed air can also remove them
An angled riser for the rear truck to change angle from 50 to 45. It does the same job as different base plate. You can cut this from a piece of wood with a saw or some thick plastic maybe. (-10deg might be easier to cut by hand) 3D print. Or local skate shop might have them if they deal lots of long board stuff.
If you have both cupped washers and flat washers, run cupped washers in the rear and flat in the front for less rear steering relative to the front.
Run the rear truck a little tighter than the front. But dont go crazy.
You can strengthen your ankle and calf muscles to give more control. I dont know the best way to do this apart from time on the board but if you have the trucks really loose it forces you to control your feet more. So maybe run the trucks really loose and ride around at slow speed till your muscles hurt. Repeat until you have that sweet muscle memory and tone.
When going at high speed put more weight over the front truck then the rear.
Since I think your bushings are shot, I suggest replacing then with something more suitable for your weight. At 105 KG, I suggest KranK 96a Canons or Barrels in the front and a Barrel or Canon / Chubby rear with the Chubby on the bottom (boardside). This set up will simulate a split setup and will also work on an actual split setup. Tune with flat and cupped washers. With RipTide, the starting point for compression is tight enough to remove all the slop out of the stack and you can still turn the top bushing by hand with some effort. With KranK, from that point you have two full turns of adjustment at your disposal so a max of 2 threads showing. If you need to go further, you need harder or bigger bushings in more positions
Hi again @Alphamail, Just want to know if the WFB pivot cups, krank magnum and cannon bushings I initially ordered for TB218 would be compatible with surfrodz RKP or TKPs?
TB 218mm trucks cone\barrel stock bushings (unknown durometer). they are really hard to turn for me, im 130lbs and if i make them loose they get super unstable also i dont feel like they come to center.
i want a stable ride (30-35 mph). if it affect the turning radius im wiiling to give up some of that. awful roads where i ride thus the wanted stability in case of a big crack on the road or something like that. setup mostly for commuting to work when weather is favorable and nice group rides on weekends.
-using evo 39 with 1\2" risers and @psychotiller six shooters pnummies, no wheel bite.
-again 130lbs with nothing but helmet knee and elbow pads.
@Wraith, Canons should work but the Magnums will notwork in the RKPās but possibly the TKPās. SZ has not shown any desire to make improvements to their trucks for years so I rarely use them anymore.
Hey @Dazeto, as a starting point take both Barrels and put them on the back truck and run both cones up front. You are currently running a symmetrical bushing setup on an asymmetrical board. The rear has a lot more leverage over the trucks than the front so you need to compensate for for the base plate differential. Try that first then report back and use cupped washers all around and when you make any changes such as this, be aware of wheel bite!
May I ask what specifically you donāt like about the surfrodz rkp? What do you think about the Ronin katanas? What truck would be ideal for you if you didnāt have to worry about compatibility with any motor mounts?
Several issues depending on what SZ RKPās you are referring to but mainly the bushing seat designs being different from each other top and bottom plus they will not accept the very popular Chubby shape as well as other iterations. I could go on and on but it wonāt make much difference.
I would like to readdress the comment above, I was mistaken on the Avenue / TKP and RKP, as they take the same pivot from us, I had a pair of unreleased Avenue precision hangers that did not work with the production base plate. Sorry for the confusion.
Interesting. So compared to caliber or paris, surfrodzās lineup has pretty much been stagnant in terms of product improvement? I didnāt realize that. Thanks for this @Alphamail!
That statement paints a picture that isnāt accurate even though your statement is accurate. I use the āif it aināt broke, donāt fix itā philosophy when it comes to standard skate hardware. Surf Rodz RKP & TKP trucks are flawless, why change anything?
With all due respect to @Alphamail, I love SR trucks, I find they perform better and last longer than any other standard longboard truck available
Yeah youāre right. There could be several reasons as to why their inventory doesnāt need any changing. And that shouldnāt always be thought of as a bad or worrying thing. Their current trucks speak for themselves when put to the test
Reading stuff like this I feel may eventually blind me to all other manufacturers. Maybe if I see 2 more of these then Iāll throw my wallet at them.
They havenāt replied to my email asking about adjustable rkp baseplates though
Not that Iām complaining or anything(just having my self control tested every time I read about SRs when pulling the trigger on them lol)
