Well, since my kid is obsessed with my eskate and snowboard (we are riding together on my board every single day), I have come to idea to make one for him. He already can ride my bamboo GT by himself, but it is simply too long/wide and heavy for him, and with 13kg of his weight he does not have enough weight to make it turn, so basically he can only ride it in a straight line. Other issue is that it is way too powerful for his age.
So what I am looking for is a short, light deck with super soft trucks that he could steer with.
I have some 5065 collecting dust, so that would be the motor of choice for this build.
Is it possible to make a board with single motor, with 6s1p battery and limited motor current to limit top speed at somewhere around 10km/s?
My guys board goes up to 18 mph (of course I have set the bushings and motor settings for myself sometimes ) but limit the the speed to about 13/14 via duty cycle.
I heart this post. My 10 year old son just asked me to build him an ESK8 and we finally have all the parts we need. Iām strongly considering starting a thread for his extreme budget build, and this post convinced me to do it
I would use a 10s1p instead of a 6s just for the fact that it will have a longer range and you can up the speed through the settings as he progresses and gets older
My kid is about to turn 16, we started skating together when he was 12, started building esk8s together when he was 13.
He scares the shit out if me sometimes, but it so much fun building and tiding together. Plus when he gets cocky, I lower his duty cycle via Bluetooth so he canāt keep up .
One option is to get a regular double kick skateboard deck and mount some longboard trucks (calliber2) on the kicks. This gives them a steeper steering angle to make it easier to turn for a lightweight. Double kick decks are super cheap. The only downside is low ground clearance for batteries and you loose the kicks.
This is great! Iām working on a build for my 9 y/o son.
There is a cheap (~20$) maple board from aliexpress down there somewhere in the thread that some people said looks ok.
@Sender and others: one question I canāt get an answer to, is what is a reasonable āAvg. Energy Useā - set as default to 18W-hr per mile in this calculation. I assume I can lower it significantly for a small 30kg rider, but Iām not sure how much.
