You have tiny battery problems mate. How strong we can brake depends entirely on how big our pack is. The max amount you can “regen” on a 2p pack is about 10 amps but you can only expect that on a partially discharged pack. If your pack is small the voltage will rise quickly when braking and trigger an over voltage.
It would also be helpful to hear what gear ratio and wheels size you are running. A 270kv motor is like having really tall gears so if you are not using a proper ratio to bring the theoretical top speed down to a level better suited to a 10s2p battery you will have issues.
Yeeww, board was set up as a screamer! With that set up you were pumping massive amounts of current when braking. A battery 3 times the size of yours would have still been struggling with that setup. If you drop down to a 200kv motor the system will draw much less current.
You might be able to salvage the battery. If you have a multimeter you can check the voltage on your P groups and see if one of them is bad.
I am upgrading to a 10s5p Samsung 30q battery from @Tinp123 (he’s a really good builder with good prices) should that work ok with those motors a unity and that battery
What is your goal? Are you trying to build a death stick that can reach 50 mph or do you just want a practical board with a 20 to 30 mph top speed? If you want good brakes you need to change the ratio or the motor.
A 14t motor pulley would work with the 40t but the board will still reach around 36-38 mph so it will be on the fast side. Ideal top speed for efficiency is around 25 mph.
The VESC is amazing but it won’t change the resistance in your motor windings. Only way to change the KV on your motors is to rewind them with more turns on the stators.
I will second/third or forth what everyone has said and get motors with a lower kv. Yes the unity can handle higher erpm however you are still running the risk of issues.
please read this article about KV for each battery. Only experienced builders/ riders should be messing with kv and battery and speed.
If “cheap” is your goal, get a KEDA 6364.
If “good” is your goal, get a 6374 from @psychotiller
For something in-between get a @torqueboards 6374 (for single-drive) or two @torqueboards 6355 for dual drive.
