Ok I am ordering a lot more belts. 12mm and 15mm. Don’t see a need for 9mm because they’re just not as strong so why bother. Never bought something in such big quantity before, its exciting
Hi, I already ordered a pair of your mount. It looks awesome just base on your pictures. I’m planning on putting them on a 13-60 teeth pulley-drive wheel. What’s your recommendation for belt lenght? I’m thinking about 375-15mm belt, please correct me if I’m wrong. Thank you
13-60, that’s a unique one. What size wheels are you using? The possible belt lengths vary depending on the size of the wheel as they typically block the idler.
@Lionkev55 can you make my order 2x12 and 2x15, thanks.
I am in the process of buying the belts. Ordering a big quantity of them so hopefully I will be stocked. If it is alright with you, the 15mm might be a bit. They have to go all the way overseas!
I just made an order on this wheels and hubs
@Lionkev55 yeah that’s perfectly fine
There might be an issue with my mount and those wheels. I didn’t design them for massive wheels of that style, hmm…The head of the M8 bolt that keeps the idler bearings on might pose an issue for you. If I am right in saying that, your only option is to run the idler off and pick the right size belt from square one which I can help with
Got it, I’m gonna keep the order with you anyway. Maybe I’ll use it with my 107mm flywheels. Can you update my order with an appropriate belt length? I think I stated the wrong size on the form.
107 flywheels with what gearing? They’re the biggest wheels they support. My comparability chart says 40T wheel with a 14-16T pulley. If it isn’t that criteria I will calculate for you what you will need. I only have 325 and 320mm belts though, so you may have to source your own belt.
Sorry they didn’t work with the other wheels, but I did a lot of sourcing for a better idler and nothing was as good as an M8 bolt and 608 bearings. Waaaay cheaper and so easy to source and replace. Who doesn’t have spare 608s? Maybe next time
thank you for the support, will ship out by tomorrow.
removed the post
remove my post here
I know your just trying to run a business, but hijacking another sellers thread is not cool, he’s just trying to do the same thing. Also you posted the same thing twice which is a waste of resources. Just start your own thread, you’ll get more interest that way.
my bad, i will apologize and never do it again, it is wrong, thank you, you let me know i did wrongthing, and now i will correct it. thank you!
@Lionkev55 I apologize here, and deeply sorry for my bad behavior here post same thing under your topic, can anybody take my post off? once again I apologize and won’t do it again in future. and many thanks to @mmaner you taught me the right thing a man shoube be abide with. thank you. and people here also learn from this, my bad, my apology and my appreciation.
Why man… I flagged them but I doub’t that does anything. Remove them yourself please and thanks for apologizing.
Props to you for starting your own business! I really like the look of your mounts. I’m actually kind of bummed I already bought a set from torque boards. I’m sure I’ll be ready to build another board up soon enough though. Good luck with everything!
removed, thanks.
If only I had calibe trucks
