I used multimeter after the bms, it showed 36v
I think the bms is cuuting off, its only 36v. Doesnt make sense.
One more weird thing, that i connect bat ( after bms) to vesc, the led on vesc flashing blue repeatedly. It is like there is no amp is coming out, and the computer could not detect a usb device when i i pluged it in.
Then i switched to laptoplike charger, the veac connected to computer with no issue.
Is the meter negative going to P- or B- on the bms? You should be going to B-, assuming you have an eswitch on the bms. If you’re running a power switch after the bms, you should have the meter after the switch or it’ll always be on.
@Jinra thanks for quick reply. In the case that it showed 64% , yes the meter connected to the b- of the bms. In the case it showed 0% it connected to p-
One more weird thing, that i connect bat ( after bms) to vesc, the led on vesc flashing blue repeatedly. It is like there is no amp is coming out.
Yea sounds like you don’t have enough current going through. Did you wire battery negative to B- and VESC negative to P-? Battery positive doesn’t go to BMS at all right?
