Threaded standoffs. I guess
I haven’t looked at the design for more than 10 seconds though
Aha, so the base-plate would have a counter sunk hole from the bottom, in which this bolt goes? That would make sense.
I like that system. It’s a completely universal mount, for which you can 3D print any kind of bindings, including something like I sketched up above, so that you don’t need to use a spoon.
So now we just need someone to machine the baseplates and we can go home, right?
Very cool
I guess it’s even simpler than mine. Great job @TowerCrisis, simple and to the point.
Dani
It requires some carbon otherwise we risk losing @danile !!!
Option to use carbon tubes accepted here, personally love carbon whoring.
I’d be happy to print something out in PETG if it helps
very, very impressive.
Don’t worry.
The best idea should always win. This is the case here. Now go ahead and execute!
We can always tackle super light version in the future Dani
Impressive ! @TowerCrisis @danile
would it be possible to get more coverage above the feet? This will provide more support in the momentum in the air. See below
I can’t wait to have a ton of different 3d printable foot holds for true customization!
@venom121212 I have a mountain to dig myself out of, and a bearing thats going bad in my spindle.
And i fucked up a set of custom engraved plates last night because of a loose endstop. Hours were lost.
Oof. I F’d up my 3d print running all last night too. Not nearly as shitty as metal though. Best of luck to you with projects moving forward
Super excited about this. Great designs!
Is not the end of the world. Need new spindle or fix. Day or 2 lost is all.
Yea gareed @okp Seagull wing over the top of the foot, otherwise they are fancy footstops in essence, for you anyways you mad yoke!
The bigger we make the 3d printed part (for more foot coverage) the weaker it will be unfortunatley. I dont expect there to be any problems but in a hard bail they could snap.
I love the latest design but I think we could easily get away with slightly more foot coverage. I can print in Nylon or glass fibre reinforced Nylon or even carvon reinforced nylon if we needed to for extra strength!
great work. Happy to bring back my unik street deck back to life to test these babies.
nooooo
if its mine take your time
We can do creative solution. Just need to finalize the dimensions of the design.
Who is proceeding with this?
I just guessed at the angle of contact on my initial design and it didn’t match any of my shoes by a lot. So, I took some measurements and tried to add adjustability to the angle for varying shoe types. Rather than the adjustment by vertical screw I was thinking of a wedge concept where you tighten it’s grip by working your foot further in to your liking. The base is currently PETG and the plate is TPU with like a 15 percent infill that gives a hard rubber feel while still flexy enough it won’t noticably damage if bent quite a bit. Different bolt length can increase stiffness but may give enough leverage to where if you stomp it the base could break. I need to pick up some hardware to actually test it though.
