Ok guys, have a neat idea to make it very light.
Who can help me with aluminum machining (simple part)?
I would like to not go in the direction of bought brackets - this brings us back to low grade steel and ugliness😀
The rotating part is very important, even having these bindings slightly in the wrong place means they are quite uncomfortable.
I ride this
The metal plates that screw to the deck are not too heavy guys. The best plan would be to get those parts made in ali and then print the foot retaining part.
The other thing we need to consider is these are pretty much set and forget. Once you find your position you leave them there, so quick adjusting isnt really necessary
If you dont have rotational adjustment in the top bit that means you also have to adjust the bottom bracket too to accomodate regular/goofy swaps other wise when you swap the bindings will make your feet turn inwards instead of outwards.
This is the rough model of what I’m thinking, combining milled aluminum parts and a 3 printed binding. The binding itself will need some sort of strengthening, like an epoxy bath or CF wrap or something. I just don’t see any 3d printed filament lasting under the kind of stresses we would put on it.
Just to understand the procedure: suppose I want to use one of these, so I replace the existing hardware with longer bolts and screw this on top? Using bigger washer I suppose?
Could existing users measure the following:
The height of the vertical metal part.
The spacing between two adjustment holes - basicaly the resolution of the vertical adjustment.
The width of the vertical metal part.
Freebords site lists the weight as 1lb for the whole set, is this the case? Is it considered a lot?
So, this can proceed in two ways:
Either do a variation of the existing bindings with identical basic design and adjust to 3d printing/aluminum base.
Another idea is to use vertical pole made out of carbon. Will need redesign of the base plate, still manageable. Will greatly reduce the weight! (Honestly this is more interesting, as variations already exist)
What do you say?
Thank you!!
It can be managed, the design should take this into account.
