Ok guys, have fun!
This is alive on Thingiverse: https://www.thingiverse.com/thing:3619398
Following are the instructions from thingiverse:
There are two parts to print - left and right binding pieces.
One aluminum plate to machine, I’ve added a .dxf file for this purpose.
Any aluminum sheet 1/8"-1/4" (3-6mm) will work, simple 2D machining
And one 1"x1" T-slotted profile to get (2-2.5 inches long).
These profiles are widely spread and there’s a very good chance you might find enough around you. In case you don’t: https://8020.net/1010.html
I designed it to be cost effective with minimum “fancy” parts.
Besides the prints and the base plate, everything else can be sourced for free (in most places) or really cheap.
Here are additional stuff needed to complete the build:
1/4-20 3/4" bolt. Each binding piece requires 4, so 8 bolts total
Any head shape works (see pictures), my favorite is button head.
1/4-20 sliding T-nuts. Each binding piece requires 4, so 8 in total
Examples:
https://8020.net/3204.html
https://8020.net/3382.html
End cap. Each piece requires one, so 2 total
https://8020.net/2015-plain.html
1/4-20 1/2" FLAT UNDERCUT bolt. One for each piece, 2 total.
You will have to tap the central hole in the T-slotted profile for this bolt (standard practice) and do the undercut in the aluminum plate (see pictures)
4-40 FLAT UNDERCUT bolt. Each piece needs 2, 4 in total.
These bolts make the T-profile stay in place and not rotate (see pictures). These don’t take any loads.
The aluminum plates need to be tapped for the bolts with undercut.
The pictures in this thread are self explanatory.
And, as always, if any questions arise, I’m here, just a @ away.
If you feel like I did something right, consider showing your appreciation: paypal.me/DaniLevin
Also, special promotion, only for the weekend
Whoever buys my deck will get a complete pair of bindings with it (you can even choose blue/orange color)
Enjoy,
Dani
@Itsmedant thank you!!!
@mmaner can you edit the title to point to this post? Thanks!
