what if i use dual 270kv alien motor on a 18 to 36 gear ratio with 10s lipo and a set of focboxes. would i blow the focboxes? how fast do you think i would go?
I cant help you with the motor mounts, sry
I thnik the focboxes will handle it!
You can calculate it on a webside: http://calc.esk8.it/#{âbatt-type-lipoâ:1,âbatt-cellsâ:6,âmotor-kvâ:190,âsystem-efficiencyâ:85,âmotor-pulley-teethâ:15,âwheel-pulley-teethâ:36,âwheel-sizeâ:80}|
Yes, at 10s with 270kv you will exeed the 60.000 erpm limit, and most likely blow the drv. Go for a 190kv and youâll be all fine
Which pulleys did you use?
Will the enclosure fit 2 of these lipo you think ?
Are you still riding this? It is looking such a beauty
Whatâs the range on this DIY build?
Hey man, do you have a link to the bolts you used to mount the enclosures? They look sleek!
