Great to hear it fit everything! though I admit I hadn’t accounted for the more pronounced concave on your deck
Edit: Looks like you’ve gotten it to conform to the deck after heating it up though
Also, I thought Altar Wedge would come with a gasket of some sort. What sort of ingress protection do people normally use with such an enclosure.
This is what PT uses and what I’ll have on my build as well. https://www.homedepot.com/p/Frost-King-E-O-5-16-in-x-1-4-in-x-17-ft-Brown-EPDM-Cellular-Rubber-Weather-Strip-Tape-V25BA/100024263?MERCH=REC-
Enclosure all done.
I have to admit… with the amazing DIY work you’ve been doing the rest of this build I feel like you could do better on the enclosure. Psychotiller does a great job with everything, but ABS isn’t meant to really bend as much as that deck and reheating gets rid of the defined shape. Maybe fiberglass? Not trying to put it down at all - I’ve been very impressed with every aspect of this - I just think if you take another go at it you’ll be happy with the results.
Thanks for the kind words. Regarding your thoughts on the enclosure, that is precisely how I feel too. I wanted a tested enclosure, so went for Tiller’s, didn’t anticipate what I had to do to make it work and how ugly it might look after. Haha.
I have a pretty good model of the deck in CAD and an enclosure that I designed. So I have these options:
This is a no frills enclosure just for the NESE + DieBieMS, where the VESC is mounted just above the rear trucks. I can easily modify it to have the VESCs inside too
Dang that sucks man…
I’m going to be trying to squeeze 2 focboxes, 12s4p NESE, and a DIEBIEms under my altar wedge…its gonna be super tight!
It will work absolutely fine in there, if you have a flat-ish deck.
My deck has a agressive w shape and that made it hard.
Luckily I decided to be crazy and learn how to make decks…so the one I made for this is good and flat on the mounting spot.
Only problem is I cut the first one just a tad too short on the corners so the enclosure hangs over just a bit in all 4 corners.
Currently working on a hydraulic press to make a new deck.
Yes, I had to remove some of the corners using a belt sander. I imagine you could do it with a saw and then sand it smooth.
ok. Well you have a deck with a drop, which adds to the wheelbite. But a good reference for my build.
why don’t you print the enclosure, very thinn layer, and then cover it in fiberglass/CF. this way it will print fast and you’ll get a strong enclosure
that’s exactly the plan. I am almost about to complete the 3D printed enclosure for the other build(105mm hub motor and bamboo deck), so I’ll work on it after that.
thats a good idea.
I even got some flexible epoxy for the glass fiber lamination.
So it’s finally complete. I have the following update:
Pretty happy with it. Now I have to put grip on top. I have a transparent one. Should I use that or go with glass fritz for this deck?
what a beauty
Went for the first ride. Wow! Feels like riding on a cusion of air, , well duh! I wish I had done this earlier. My feet wouldn’t have suffered as much for the last 2 years.
wheelbite is not an issue right? Could you maybe send me the measurments from the drop? I want to recreate this with brackets.
