Hi my AntiSpark Switch stops working for some reason.
Yesterday and early today I didn’t have no problem turning it on and off with the push button.
I went for a 3km ride with no steep hills and when I come home I noticed it won’t turn off, so I opened it and checked why didn’t find the reason. The MOSFET wasn’t even hot, it was cold, the VESC MOSFETs were hotter. Is it a bad MOSFET again or the push button? Thanks in advance.
This has happened to me before, I replaced the MOSFET and got it working again, suddenly it stopped working like now…
you usually want to replace both mosfets if one fails… likely the other one died, overstressed the new and both dead. I’d test and swap both.
when they fail they usually fail “closed” - passing current. there are some videos on how to test i don’t have handy, but i’d google really quick to find and test.
Test the resistance between the source and drain of the mosfets, if you have a short it is bad mosfets if it is not a short mosfets are fine. I had the sme issue and it was the diode so check that. There is nothing else that could go wrong because the cap and resistor does not see a while lot of stress.
More robust/reliable - a simple anti-spark loop key is pretty bulletproof. Only time i’ve heard one failed i’d assume a QC issue when assembled (faulty), or more likely user error (not fully seated and try to push 50A though it under load).
Hey @Eboosted sorry for the late reply and thanks @goldenHusky for tagging me. Hopefully I can help you out, can you post some pics of what switch/MOSFET’S your trying to replace or upgrade? Also try to explain a little more what exactly your trying to do.
