What is about Hyperbeast that you like so much ?
the kicktaaill haha
Size, carbon, weight , sexy Your option only misses the carbon but I can live with that
Ohhhh… Do mamy sleeples nights to make it compact and you don’t like the size?
Sorry, didn’t get it
As I understand you like the Hyperbeast size which is biger than my mov-e deck. You think it’s to small?
I thought it was the same size as yours But I prefer 30" max
Hyperbeast is 36"
btw do you have plans for making the deck splash resistant like the haya does?
If not just use silicone
Any news ?
They should be send today but because Christmas everything is taking super long. Soon as I got them I’ll post pictures and let you guys know.
Yes, there are goind to be some sealings and also working on easy removable griptape that will act as extra sealing also.
Thats perfect, I just got myself a Hummie hub kit for this beautiful deck What are the measurements of the enclosure?
It’s 140x550mm. Hummies…oh man I envy you right now
what about height? Yeah, couldn’t resist
So, what about it? I’m looking for suitable batteries, want to get the maximum out of it
Oh sorry… It’s 23mm. Battery have to be tightly build but I I’m able to fit there my first pack that I build and belive me it’s far from perfect
I almost ordered 8x3s1p Lipo or 10s4p vtc6 but reason set in and told me to wait for the deck Since I didn’t listen to it when buying the Hummies I’ll do this time I love N.E.S.E. modules, they give me a feeling of control over every single cell. As far as i can tell, a (6x)2s3p module would fit in there too, I would have to drill not very deep holes in the sides for the bus screws… But without N.E.S.E. a 10s4p fits. With the Lipos it would work to get a 10Ah 12s pack consisting of said 8 3s1p packs, but I’d have to get two in parallel for this and I want to CONTROL EVERYTHING () the Lipos are 23mm in height, will this be too tight, might it work to remove the cover, I’m starting to get crazy
edit: 12s3p N.E.S.E. made it, this time I ordered only the metal parts. I’ll modify the case to fit the deck 100% Its more expensive than the spot welded version but I can check each cell if I want to Other advantage is that I can take apart the whole thing for boarding an airplane :).
