These worked great with the SR TKP trucks. Had no problem putting these on. No clearance issues with Tillers mounts either.
Is anyone else using Popocas? Theyāre arenāt listed on the compatible list but Iām using them anyway since I like kegals and feel 90mm is that great point between big but not to big.
I feel like because the way the wheel is , causes issues where the belt touches the wheel in a way
Any advice ?
Iām not using those wheels, but have faced this issue. Just us a couple speed rings to push the wheel out a bit and you should be fine.
Pretty much what i do, i have the same issue with different wheels and pulleys and i use 3 then i flip the nut on the end so the nylon is turning in to the inside.
Iām am out of stock on that option
Is there a timeline on when theyāll be available again?
Not for a while
Do you still have alot of the 36t ?
Yep I do!
You still planning on stocking more sizes of motor pullys? (18t,20t)
Idkā¦ I have some big decisions to make after the holiday season, so we will see. If I do it wonāt be till 2019
That sounds ominous. You best not be going anywhereā¦
Finally decided to pull the trigger on a set of these 44t pulleys. @akhlut thanks for the write up about the 6000 bearings!! Iāll be following your footsteps precisely. Did you ever try the .006" shim? I am curious if it would be the slightest bit too thickā¦
Also, your Mcmaster recommendation has changed my life! Iām in awe. Next day delivery? Amazon doesnāt even do that most of the time. AAAANNDD they have shit that I search EVERYWHERE for. I canāt get over how badass that company is
you will not regret those @jlabs pulleys - perfect alignment every time. i have both shim stocks. ill send you both thicknesses to try.
and yeah, mcmaster is a game changer!
That rocks, Iāll pm you in the morning!! I knew Jared was on to something with these. He and I met up for a ride a little while before they were released. I could tell how much he had to say about them, even though he couldnāt risk saying it at the time. @JLabs youāve earned ALL the support that āus peopleā give you. Now go ship my order out first, lol. Congrats on your success
Thanks for the kind words @akhlut!
I will need some time to process orders. You crazy peeps pushed them well into triple digitsā¦
Dat gap tho
