I think damning a sales thread with subjective experience trumps that but hey you don’t think PETG is a good material for pulleys and that’s fine for you. I’ve printed pulleys in PETG and they did not fall apart and that’s fine for me
Let’s beg to differ and see if this thread fills up with ‘mine broke’, I haven’t inspected them but it would appear he knows what he’s doing and has tested Nylon and decided against it
Yes, but you need to adjust the sprockets lenght, because this Electric Flywheels are 11mm wider than the Superflies. Take a look at this superimposed image of the old Electric Flywheel (my wheel, with dull color) against the 107mm Superfly and 97mm Refly which share the same core, but in which you can clearly see how ABEC shaved 11mm out of the inner face of the 107mm Electric Flywheel to create the 107mm Superfly…
…therefore, if you create a wheel pulley for this wheel, you need to consider enlarging the sprockets 11mm more than the actual wheel pulleys you sell for Superflies now, so the pulley could be use effectively with the Electric Flywheel.
I don’t mind the price increment as long as you can make the pulley to size. The sprockets should be the same thickness, just 11mm longer than you usually made them and making sure the pulleys inner ring grabs the hubs urethane conical inner face.
My V2.0 (with bolts and nuts) for Abec Flywheels is done !
Specs:
-with 26mm bore - Compatible with 99% of the skate trucks (paris style, caliber…)
-retainer ring with 4 holes X1
-bolts and nuts to fix the pulley on the wheel X4
-available from 33T to 44T and 12-23mm width
Price:
from 33T to 39T : 10 Euro / 1 pulley / 12-17mm width
from 40T to 44T : 11Euro / 1 pulley / 12-17mm width
Just wanted to leave a quick reply. Szatyi makes really great pulleys! They are sturdy and really well-made. I fired loads of questions at him, and he could answer every single one of them. He made them quick and kept me up to date.
Felt like he deserved this review . Good luck with the rest and will definitely recommend you for future orders.
