I believe it’s the first week of June.
Yea should arrive before then.
I found a pair of sealed 6374s in my box. One of which failed motor detection. I’ll try again. If it doesn’t work, I’ll hit you up for a pair.
Thanks!
UPDATE: Current ETA is May 25th There are 5 public holidays in China between now and then.
Sorry if this is the wrong place to ask but is it possibly to retrofit sensors to a non sensored SK3 ? If so where do you get the sensor boards ?
Want to know too.
@MasterSpoon @xsynatic yes you can add hall sensors to sensorless motors. APS sold the pcbs, but they out of stock for 63mm motors. Might just need to write them a mail and ask about it.
If a outrunner is to tight inside for to add hall sensors, there are pcb boards to mout them outside. just have a short search in here and you will find what you need. It would be something like this http://e0designs.com/products/hall-effect-sensor-board/
One thing to be aware, get the right size board. Not all motors with 63mm are really 63mm. I think the sk3 is more slim as well.
Last option would be to use and AS5947 encoder instead of hall sensors. That would be even more precise than hall sensors.
@Andy87 Any idea what sensor boards the factory is using in these ? I have looked through this thread and the last one but doesn’t look like anybody has been kind enough to pull one apart and show the sensor circuit.
@barajabali any chance the factory will sell you the sensor circuits so we can retrofit to Sk3 motors we already have ? or any chance you can pull one apart and take some photos of how the factory has implemented the sensors ?
Unfortunately I can’t tell if 63mm would fit on the sk3. Somebody would need to measure that.
Does anyone know if 2 of these will fit on a surfrodz tkp with 90mm shoulder bolts?
Maybe. These are 80mm sr axles but that won’t matter for the space. I think there was still some more space to move the mounts further out but not much. I’d say it fits.
Ordered 2 x 190 and paid.
Received thank you
Only 2 190kv motors left available.
There are 3 which still need to be paid but are currently on hold.
Just got em
Please use the shipping address in the note on the order.
Received thanks!
Motors are all sold out!
Thanks guys!
Lucky that I found this thread in time! Just happened to be browsing after realizing that I’m not going to kill myself quickly enough with just 6355s.
Hahaha good one
