SPECS:
300mm sensor cables and phase cables
10 awg silicone wire
5.5 mm bullets
Extended 40mm shaft 8mm shaft dia
Jst mini 2.0 plugs right into any vesc
14 Pole
Actual size 6085
Power 3500W Peak
Voltage- 6-13s
Keyway
DIAGRAM:
PRICE:
$110 per motor shipped in the US
$125 per motor shipping internationally
ETA:
30-45 days from order time (Not from when YOU order but from when I place the order. I will need the the majority of the order to be placed initially. I will need to meet an MOQ of 25 Motors. When we get to 15 or so, I will place the order. I think we will get to 15 within a few days, so we should be on track.
Please fill the form out. Please pay ahead of time if you can. It will help me to afford to order the motors sooner. If you need time, message me and I can spot you for a bit. Limited spots available.
As the sensor plug is already a 2mm JST, wouldn´t it make sense to ask for 10cm longer sensor wires (or 10cm shorter phase wires) to compansate the phase wire lenght comming from the esc?
It is this. Just with custom length shaft, 10AWG phase wires and sensors.
For picutures you could have a look in the old thread, there might be some if I remember right.
@rich@taz i don´t think you in an actuall need for a sensored SK3, but I non the less wanted to tag you in case that could be interesting for you and you didn´t see it anyway.
I add „sensored“ to the title to make it a bit more clear, I hope. I‘m not the OP so better @barajabali will answer your question, but the motors should come with a slot for keyway as I understood.
Just this time it will be only 30mm shaft instead of 40mm like last time.
