Hello guys!
I’m planning to add 2 more makita batteries for my skateboard power. At the moment I have 4 batteries 18V 5Ah. 2 in series and 2 series in parallel = 36V 10Ah Right? Not enough torque. I would like to launch like a BajaBoard )))
I’m Planning to add 2 batteries in series to have 36V 15Ah.
36V 15Ah OR 54V 10Ah???
I have on my board:
2 motors TURNIGY AERODRIVE SK3 - 6364-245KV BRUSHLESS OUTRUNNER MOTOR
Specs:
Voltage: 10S Lipoly / 37V
RPM/V: 245KV
Internal resistance: 0.018 Ohm
Max Loading: 70A
Max Power: 2700W
Shaft Dia: 8.0mm
Weight: 718g
2 ESC FLIPSKY FSVESC V4 50A SK8-ESC w 5V 1.5A BEC for Electric Skateboard RC Car I7O8
I’m going to replace my 103mm rubber wheels with Mbs 100mm because 103mm rubber wheels are vibrate a lot
Mbs All Terrain Skateboard Wheels Set 100mm Black
Please HELP me to program the ESC. I’ve tried different settings but not happy with result.
Motor:
Can I put 70A Motor Current Max?
60A for smooth Motor brake?
Battery:
What is Battery Current Max? 6 batteries Makita B1850 18V 5.0Ah = 36V 15Ah
What Is Battery Current Max Regen? Is it Charging from breaking? How many A I can put?
Fully charged 2 Makita batteries have 40.48V (20.24V each)
Discharched 2 Makita batteries have 28.44V (14.22V each)
Can I put 9 cells (37.8V) or 10 cells (42V)?
battery Voltage Cutoff Start 30.3V?
battery Voltage Cutoff End 28.5V?
PPM Mapping. Just copy numbers from VESC to Pulselenght Start/End?
Thank you in Advance for your help
