Cool cool, thats awesome. I’m running the same setup with shaven MBS right now and a 13t motor pulley. Did you have to do anything with the spacer between the bearings? did you have to add some more speed washers to fill in the gap?
I took those spacers out temporarily. @dotruongq and me will go to Home depot to find a small diameter tube to make a correct length ones.
I’m using Trampa parts between bearings inside wheel.
BEARING SUPPORT CNC PRECISION SPACER - HYPA HUBS ON 9.525 AXLES - 9.525MM X 13.525MM X 18.2MM
I did try to put washers between them, when applying pressure washers touched the rim of the bearings. The result was wheels didn’t spin smoothly, I should have used smaller washers but I don’t think it would work either.
do anyone has video for 6’’ at wheels riding on field to share here? we much appreciate your contribution here, whoever reviews here and in any case wanna buy stuff from us(www.diyeboard.com) in the future, will have special discount from us.
were you using regular washers? speed washers should not impede the turning of any bearing?
video later next week
I got to ride around with the wheels and it’s a completely different feel from traditional wheels. I quite like them and agree with everything that @mmaner said. I want to put some more off-road miles on them but for rough roads these are a no brainer. (Full disclosure: I have not tried actual pneumatics yet so cannot compare)
Would anyone in the USA or Canada be interested in a set? I’m considering putting them on my store. Should be cheaper then buying 1 set direct (their shipping is $40). If so let me know and I’ll see what I can do.
I’m interested in a set of 4
I might be interested in a set in a couple months
I reaaaallllyyyy reaaallllyyyy want to run @psychotiller’s six shooters but $300 is too steep for me
I’m definitely interested in a set
Who want to try our 6’’ AT wheels, please message me privately. thank you! http://www.diyeboard.com/6-15050mm-70a-airless-allterrain-offroad-skateboard-wheels-p-568.html http://www.diyeboard.com/6-15050mm-70a-airless-allterrain-wheels-with-hubs-pulleys-p-587.html
Anybody knows whether they would fit onto the Evolve AT hubs?
what’s the evolve at hubs specs? you check thread through, there’s our hub size and fitting specs in photo shown by measurement.
http://www.diyeboard.com/6-15050mm-70a-airless-allterrain-wheels-with-hubs-pulleys-p-587.html We have hubs and pulleys, if you need to try other hubs, take this for reference, we have 9’’ AT truck to fit our 6’’ AT wheels Axle length of 38mm, 8mm axle diameter
Wheel Size: 150mm x 50mm Wheels Hardness: 70a HUB Size: inside diameter: 64mm, outside diameter: 103.9mm Hub Width: 44.3mm, inner 31.4 mm width HUB Axle Diameter: 8MM Bearing inside diameter: 8mm, Bearing outside diameter: 22mm HUB Teeth: 60 Pulley gear ratio we use 13:60, HTD 330 5M belt for 5065 Motor Mount.
