Is it better to have long battery cables/ canbus wire or three long motor wires (putting the vescs together on one side vs one on each side of the battery)?
Definitely long motor wires. A long batterie cable is more problematic.
If you use long motor wires you probably cannot use FOC.
Im glad I asked the question now. Thanks! Any problem with a long canbus wire?
What kind of problem’s?
I don’t know exact what happens, but on FOC you will get problems. @elkick could explain or link his old post. If you add more caps in the line it can be okay.
