Saw that in instagram and thought that it was a heat exchanger for a water cooler, sad it wasn’t, but it can be one day right?
The enclosure sits in place
How it looks from inside
damn… that’s rad.
I count 6 holes on for phase wires. What’s the plan for the sensor wires?
Received the cells for this beast
What battery size are you aiming for? 12s 10p?
Yes 12s10p
That will allow for around 200A constant… Good luck!
Well I wouldnt be sure to pull more than 15A from 30Q
This is how our battery enclosure will look. 2 floors of these Design will change a bit with space for wires
Mind if I ask where you order your cells?
Damn the stuff you can do when you’ve got your own commercial grade milling equipment is crazy.
Nice. Still waiting for mine. Probably helps a whole lot if you’re already in Europe can’t wait to see the cells in place!
Nice, compact between the feet, maybe a bit high but what a range you will get !! #jaloux Edit : can’t to see the full form factor
If these are mounted on top of the deck, the worst case scenario would be if the cells shorted and started to fly towards the private areas
Well many trampa off road builds puts batteries on top Deck is to flexy to make something this size under it Plus it will have lid so nothing will go up
Working on the enclosure for the cells
Milled some FR-4 for insulation between stacks to prevent in the accident when plastic brakes shortenings or etc from happening
