2 chargers in parallel will not work Just use a high amp charger or build an adjustable charger
Ok, so if I want to charge with two chargers Iāll have to disconnect the parallel connection. What do you think will happen?
The chargers will blow fuses if they have them or burn up the pcb Plug 2 chargers together right now see what happens , you donāt even need a load
No, I didnāt wanna try that myself lol. I was hoping if it works itāll charge twice as fast. But donāt wanna risk. Btw, asked your question to Lillian. Iāll let you know.
They show up yet?
Thatās a great deal ā¦do you know if they have 12s options as well ?
Not yet. It seems itās not 7-10 day thing. Iāll post here if I get it. Your build is looking good, btw!
Man, I donāt know that. They only list a handful of packs for 10s config which is the highest voltage in the menu. You can always ask them for it. Lillianās email should be in the photos I linked.
Iāve never actually tried it, but in theory it should work fine
If you hook up 2x 2A chargers in parallel, the total DC output would be 4A. Even if the chargers have a 2.5A fuse, for example, you wonāt blow any fuses because the current through each charger is still only 2A. Itās the same concept as putting two batteries in parallel. And the AC to DC conversion isolates the signal, so you could even put the AC plugs in parallel as well
Thanks Working on making it pretty now.
Big no no!!! You will blow your chargers and potentially a fuse in your house.
The chargers will never ever be at the same voltage and depending on how far off they are, one will charge into the other. The reverse flow of current will burn the charger and in turn create a short in your wiring. Depending on how good the circuitry is, you might get lucky and not burn anything else but you could start a serious fireā¦
Ah good point. Couldnāt you solve that issue with a diode on each DC output?
The voltage drop on the diode might throw off the charger, it wonāt see end voltage
How did the packs work out?
Theyāve been working fine for a month. No doubt 30Q cells. Iād recommend them but I canāt seem to order from their site anymore in US.
How long did it take to deliver?
Fuck sake ye get all the good deals in the us
It took 24 days to get it in US by fedex.
Theyāre a Chinese company. Probably they ship internationally.
