Im not 100% sure yet either… I think when I will need to I will try to contact the airline company to let them know I will have extra ‘‘dis-assembled’’ li-ions with me in handbaggage…
Basically with 6cells it should be the same as with laptop cells (if considering the size)…
Non the less… im not sure do they check are they certified/ manufactured profesionally or not… but I know that in some airline rules it is mentioned that battery terminals should be isolated and that’s it…
I actually got the idea from here:
A while back he posted his battery pictures in picture thread… and I was like… oh I need to make this, too!
Yeah I don’t think they know enough to really question it if you have the right documents. My only concern is, if I’m shrinkwrapping those myself, that they might look a bit sketchy (the ones in the thread you linked looked really nice until he used electrical tape to wrap them in a nice black pouch with just two contacts sticking out, looks a little too bomb-like for my liking). Since I already have the holders though, I guess I’ll just test them and hopefully this works ok.
The best is probably to get the right size heatshrink wrapping…to make it somewhat professional… then maybe print out a label that it is made in unknown chinese factory or such
Yeah clear shrinkwrap covering the terminals with a nice label stating the voltage and capacity, if done correctly, would probably look fine. I’d probably want to spot-weld them together too. I’ll just do that if these holders don’t work out, the university I go to has all the right equipment.
I think you’ll find with one wheel at the back and only one truck at the front, stability will be worse than with two trucks because at least the truck at the back contributes to the resistance to not let the deck flop over from side to side.
You’d normally have two trucks with their bushings resisting flop, whereas with this design you’ll have just one, so you may want to go with extra hard bushes on your front truck.
Other than that, cool design, I like that it’s something different.
Yeah, I thought about that, forgot to include it in my post. I’m probably gonna buy an extra-wide front truck (maybe even >200mm wide) to make the wheelbase larger. However, since most of my weight is on my front foot that should help with stopping it from flipping over while riding. Turning might be an issue though, my turn radius will probably be huge. We’ll see. Worst case scenario I buy a truck and motor mount and convert my build to a regular 4-wheel design, it would be pretty easy to do.
EDIT: Also, thanks for the feedback, and I’m glad I’m not the only one that thinks it’s a fun design!
Ok, board got here and started building various parts. Still have to make the motor mounts and back wheel mounts but that’s about it (and order the motor, but that’s just a click and maybe 2 weeks shipping away whenever I decide to bite the bullet and buy it).
Anyways I don’t have too many up to date picture but I built my own fiberglass enclosure a couple days ago.
2 layers of fiberglass (which is way too flexible, probably gonna epoxy some sort of stiff material on the inside, almost regret not fiberglassing onto the foam mold I created which was hollow).
Here’s a picture of the layup (would not recommend using paper to protect the table, especially if using peel ply, epoxy got through all layers and the paper was a pain to remove):
And after it was unmolded and about to get painted:
Looks decent enough, kinda wish I’d gone grey instead of black but eh, can always add another layer of paint:
Bit of door insulation strips and silicone caulk for waterproofing:
Bolted on with m4 bolt wood insterts (don’t have pictures of putting them in unfortunately), will be adding stiff strips along the sides to put pressure along the whole length to keep a tight seal:
Sits kinda low, but I’m gonna top mount the trucks so that should give me a nice 20mm extra to work with, I also rode it to campus a few days ago and didn’t get in the way so I think it should definitely be fine after I top-mount the trucks.
Will post more pics of the back wheel pulley assembled and the battery holders with BMS connected in a bit, they’re not with me now so I have to go get them.
Ok! Took me a long time to update this post but I’ve done quite a bit of progress since last time. Just have to machine the back wheel mount and reprint the motor mount and I should be good to go!
So first of all, one issue I was having was the enclosure being way to flexible and not holding its shape too well, so I added thin balsa strips to the bottom and a third layer of fiberglass on the inside to create a kinda corrugated layer of fiberglass. That helped a lot with the rigidity of the bottom of the enclosure.
I also added a few aluminum strips to the sides (though I might remake them, I didn’t have any aluminum sheets that were long enough and the holes don’t line up perfectly which ended up with me ruining multiple brass inserts (brass is really not very strong).
You can also see the motor and motor mount version 1. I have a better design for the mount but it’s really convenient for testing out the vesc on a table
I also finished my battery holder and soldered on my BMS.
And it actually charges!
A picture of my wheel and pulley (just bolted onto the wheel, it’s 15mm wide which hopefully means I never have to change the belt ever, but that’s probably not the case.
And a picture of the other side, just 3d printed washer thing to hold the bolts in place.
I also got to try out the VESC and apart from a wierd problem with the temperature sensor, everything seems to work which is great news. I’ll just have to make sure I test the battery holders for the kind of currents I’ll be seeing (it’s 10s4p though, so hopefully that’s ok). Slowly making progress though I’m going to be gone for the summer so if I finish it it’ll only be in september or later. Only thing left is to reprint the motor mount (or better yet machine one, but printing is less work usually) and machine my wheel mounts and I should be good to go!
I also top mounted my trucks and it looks really nice and actually rides better (cracks aren’t as much of an issue because of the extra weight and inertia of the board).
Picture (corner looks a bit funny, the aluminum strips are still taped on, might just use wood strips so I want the aluminum to be removable but it doesn’t look the best):
Really excited to try out this board once it’s finished.
Always good to see innovative design ideas here.
Seems like your turning radius will be decreased with only one truck. The rear truck contributes to turning the board (four wheel steering).
Motor looks pretty exposed to curbs, debris, etc. But maybe it just looks that way in the rendering.
Good luck!
Yeah we’ll see! I was looking for a cheaper way to mount the motor and all things taken into consideration it might be a bit cheaper than two trucks and all the mounts to attach it to the truck, but not all that much (small parts add up).
I’m hoping to 3d print (and maybe also fiberglass) a cover for the motor to shield it from debris. It will probably break if I hit something too big but at least the first thing to hit won’t be the motor, and hopefully the front truck flattens the bigger debris before they get to the motor. I’ll also have a bit more clearance than on the cad since I’m top-mounting my truck (and will probably make spacers so I can adjust the height of the back truck.
The turning radius is a bit of an issue as well as the fact my wheelbase is a triangle which makes balancing a bit funky, but I guess we’ll see. Worst case scenario I can just buy a pair of caliber trucks, some ABEC wheels and a mount-pulley combo and I’ll just have a normal board, but hopefully this works out!
@cricrithezar Why did you choose to build such 3 wheeler in the first place? Did you also wanted to get ‘‘snowboard’’ feeling… or is it just for better turning radius?.. The only other board with this kind of concept i know of is the commercial LeifBoard.
I didn’t like having the motor mounted to the truck because that either meant having to put really tall risers on (because as the truck turns, the motor mount makes an arc that can intersect with the deck) or having the motor dangerously close to the ground or sticking out the back which isn’t pretty or stealthy (I want it to look like a non-electric board at a glance).
Otherwise the turn radius will probably worse and balancing on it will be a bit harder (not much, just have to make sure to keep most of your weight either near the front, which I will be doing most of the time, or near the center since the wheelbase will be smaller and triangular.
EDIT: My other option was hub motors and I actually would love a pair, but I also wanted something powerful and relatively cheap and even low kv hub motors are still pretty high kv since you don’t have a gear reduction in there. This was the best solution for my purposes (at least I hope, we’ll see how this turns out).
Ok! Took me a really long time but slowly getting stuff done. Currently getting the motor-mount 3D-printed by a friend and just made some (hopefully temporary) wheel mounts out of a random piece of wood I had laying around. Hopefully I can machine some aluminum mounts at some point though.
So now that I’ve ridden it, I’ll have to say. I really don’t recommend this exact design haha, it’s really funky having the whole board tip as much as it does with only half the resistance to roll since there’s only one truck. You also have to keep a ton of weight on the front, which isn’t a terrible thing. I haven’t taken it too far and it’ll be very different when I don’t have to push but I’m definitely considering building a board dedicated to this design rather than using an off-the-shelf deck. Might make it more triangluar and find a way to have the wheel axle right on the deck so it’s not as tippy in the back. I also think I have to tighten the trucks some more. I’m going to end up with a board that can barely turn haha.
Might fiberglass the mounts, they’re not quite as strong as I would want and I’m worried about cracks. Hopefully I can test the whole thing soon, motor mount is the last thing that needs to go on the board and then hopefully I can take it around and find ways to fix the issues I have with the design.
Use an evolve supercarve truck maybe? Not only are they super-wide but they are double-kingpin so hopefully you’ll get both trucks’ worth of flex out of just one truck. And the 306mm length gives you more leverage on the bushings to turn tighter
I like the evolve supercarve suggestion. I’ll definitely look into those, was looking for larger trucks but was affraid that’d limit my turning even more
The wheel doesn’t fit all the way but there is extra room for it if I want to move it up a bit. Maybe I should do that. The main limitting factor is the pulley sticking off the side of the wheel hitting the base of the mounts I made. If I make them out of aluminum I can shave off a bit more thickness but still not all that much.
…thinks out loud… I wonder what would happen if you put a 15T gear on the wheel that went to another 15T gear … then you could scoot the wheel way up in the deck, maybe even use a 150mm wheel, maybe even run the axle directly through the deck and not have a mount at all …
The wheels would probably spin real fast and with that diameter I probably wouldn’t get enough torque. The 3-1 ratio is solid at 10S and 190kv I think. Also i’d need to build a board that can fit both the wheel and pulley in the slot as well as room for the belt which means I’d probably have to either mount the motor in the slot as well, or on top of the board. Maybe something like this with a longer and wider slot in the back and some metal brackets to reinforce the board.
It’d probably end up being quite a bit of work to get working and wouldn’t give me as much clearance on the bottom so I’d have to integrate the electronics inside the board (probably a thick deck). I’ll have to look into it. Gonna try out the board as is this weekend hopefully and see what happens.
I guess that’s one way of doing it! Starts getting pretty complicated though, might be easier to drive the wheel axle directly and have the pulley off to the side, though then I have to mess with bearings and build adapters for the wheel. Right now the pulley is mounted directly to the wheel and I’m using the stock bearings that came with the scooter wheel. I also realized I can shave off a good centimeter or so by machining them out of aluminum. Hopefully that’s enough to help with the tipping. Might also mount the truck drop-though again even though my ground clearance might start getting a bit small.
