I’m selling a few items. As there are so many, I currently don’t have pictures or prices for them all. If you’d like to enquire about a specific item, please post below or PM Me. I am sorry the pictures arent uploaded here, but this is a reddit crosspost
Light asthetic wear on the trucks. Checked thoroughly for microfractures and couldnt find any
100% Operational with all evolve parts
£660 UK Collection (~45% original cost)
Loaded Fat tail w/ Metal ESC & Battery enclosure, 10S2P Sanyo w/ Dual hub motors and chinese ESC (Recent meepo ESC, I use the 2 speed remote because it gives the board higher torque) https://imgur.com/a/iDipBjT
Venom bushings
Paris front truck
Under 300 Miles
Under 75 Battery cycles
Rear hub motors replaced less than 50 miles ago. Small rock has been embedded in 1 hub, but this usually wont effect the lifetime of the hub (hasnt done for me in the past)
Asking £350
Loaded vanguard meepo deckswap - 4.4Ah LG Battery & older meepo ESC - Recent pictures unavalible. Can be seen here - https://i.imgur.com/LRPrO7n.jpg
Back hubs replaced very recently, near new
Under 500 Miles
Under 250 Battery cycles
£230
Landyachtz EVO 10S5P Diyeboard airless tire offroad kit. Newest gen ESC (Smooth for a rider at 160lbs) - https://imgur.com/a/2upzr1s
Battery sag is only noticable at 25% battery, probably better than my evolve.
Rear tires fairly worn, may need replacing within 300 miles but may go on much longer depending on rider weight
The battery casing is quite tall, and can scrape against the ground if ridden off a sharp slope or over speedbumps, it was also chipped by a rock and has been sealed with tape for 300+ miles
£470
Flywheel clones (85mm) 78A. Never used, not even on test bench. I think i may have pulleys and belts for these too, if anyones interested in them let me know and ill look for everything. https://imgur.com/uAGUnua
2x diyeboard N5055 270kv Brushless motors. Never used, not even on testbench. Asking 50GBP - https://imgur.com/DQjCTJV
Older meepo Dual ESC. the off switch function is BROKEN, however the ESC CAN be used with a inline powerswitch and should function regularly. Asking for 20GBP - https://imgur.com/PZKx7qr
Completely new dual replacable PU hub motors from diyeboard. 6 spare hub sleeves, asking 130 GBP - https://imgur.com/C6nP8Cs
Please read the thread. I am likely not going to end up selling everything, so please ask about things individually. I am not going to put prices on everything because i’ve been told everyone lowballs them even further on here.
I didn’t want to take pictures because it mostly looks new, as described in the thread. Also there would be so many pictures, so if you are interested in anything specific then ask for pictures/details
Yeah I’m going to need pictures bruv. You’re selling on hopes and dreams. I have no idea what connectors, layout, dimensions, condition… I hate to repeat everyone else but pictures will help. Even if its one of each item.
by rules you need to post a pic of every item your selling
easier to post them on the thread for everyone to see than to pm them to each possible buyer
If you were to buy an item from me, especially if its a complete, surely you would like a picture attached to the listing?
Even if I offered multiple items, you (normally) want to see the item to choose so you dont have to bother the seller asking for information that should have been a given. Now I (you) look silly for wasting your (me) time, and I would want to leave. just like @brenternet
