I am building a bord with the same board and enclosure. However I am almlst done but I can’t make it fit under the trucks without going with 2cm ground clearance. I have the tourqueboard motor mounts and they seem to not work with this build. Any ideas on how to fix it? What mounts did you use?
Use these wedged risers.
Angled Wedge Rubber Blue Riser Pads 5/16"-9/16" (8mm-14mm) ABEC 7 Bearings 1.5" Hardware https://www.amazon.com/dp/B013LMO48W/ref=cm_sw_r_cp_apa_gtM5zbAPPPMND
How much are you asking for that skateboard
What board for sale?
I use the motor mounts. They have been working great. But it looks like he’s out of stock now. http://www.electric-skateboard.builders/t/pulleys-out-of-stock/16586
