Just ordered a pair from your site… cant wait for them to arrive
@Boardnamics Have you ever considered making the connection between the arm and the clamp to have several fixed position holes instead of being a continuum?
Im running tb 218s on 63mm idler mounts with @dickyho 6x2s i used a dremmel to take 1mm off of the mount it fits perfect. Took like 3 minutes. No. Big deal
Ehh…not really. I have yet to hear of an incident where my mounts come loose. Because every bolted connection has a nylon locknut, it is already very hard to take off. That combined with red loctite and it would be too secure. A real pain to ever remove.
Just so youre and everyone else is aware, no filing was needed with my 218mm and boardnamics mounts mating.
I appreciate the slotted holes because different applications will require different motor plate angles. If you really want fixed angle setup your probably better off fabricating your own mounts
Wow, lucky perhaps. I tried to fit without filing and could not.
You can still have many angles by having several holes very close to each other.
thats using ur noggin lol
So I didn’t even get out of the driveway before I gouged the corner of the mount, lol. And, I found out the hard way to keep the motor plates loose until the hanger clamp is good and tight
That’s a sexy enclosure you got there
I know, I sold it to him😁
I was wondering if this would work with the DIYEBoards kit to replace their shitty motor mounts? I have an extra caliber II truck laying around and want to put these on it. The kit has 5055 Motors, a 13mm pulley and a 12mm 250-5m belt.
Sounds like it would work. I am running low on 50mm motor plates however, but have plenty of idler ones that fit that. I also have the belts for that
Thanks for the super fast reply… So this (https://boardnamics.com/product/motor-mount-for-electric-skateboard-v2-0-w-idler-gear/) would work? Should I get longer belts like the 320mm?
Yeah that’s the one. 320mm belts will work.
Can vouch for this, lost my nerves and almost decieded to get a blow torch and melt the whole truck lol
