That looks really professional I love the font
I learned the hard way which direction the bolts on the truck clamp are supposed to go xD.
What happened? I sorta mounted mine with the head above actuallyâŚ
I highly discourage that now especially that I use button head screws. The head is slightly wider than the clamp, so it could make the arm bottom out on the clamp.
Bottomed out on the curb with spectacular sparks.
Bolt was scraped at an angle.
Nice jk donât sue please
Ok ill remove and flip the bolts. Luckily i have not ridden it yet.
any update with the 3dprint file for pulley covers?
canât wait!!!
Mounts are great . they are head turners for sure
Where do we order for surfrodz?
@Boardnamics. Question, I already have the non idler 63mm ones. Will the idler mount fit to the clamp provided with the non idler? I need a slightly longer mount.
@pookybear I took the pics, now just editing. Listing will be up shortly. If you need them ASAP, PM me cause theyâre ready to go
@ThermalChild yes it will. I can offer the pieces individually
Oh sweet, Yeah I wasnât trying to have to realign the mount again as it is legit perfect. Do you currently have them in stock or would I need to wait for next batch? Either way not a problem as so far this mount is a beast.
I have a lot in stock. So just an idler arm and the idler hardware? That would be $12
Iâd need 2. Also how much longer is the idler mount compared to the non idler? Are they the same thickness too?
Sorry, was gone a few days. The idler mount is 12mm longer than non idler. Thickness is the same
Does the 6374 sk3 motor fit along with a support bar? I got the mounts in but donât have a motor to test for myself. Seems like there wonât be any room for a support bar since the motor is pretty large. Thoughts? @Boardnamics
