Alrighty little update. Finished the arm pieces, now moving on to the clamps. The finishing process takes the longest time. The actual part time to cut these out is 6 minutes combined, vs around 8-10 minutes of finishing operations per mount.
I am gettting Surf Rodz TKP trucks this coming week so I should have the design done for that real quick.
My next big batch of mounts will probably be 500 count vs the traditonal 100 I have been doing. It would take me roughly a month to make 500 mounts but it could mean I could ship same day as order placed.
My biggest flaw right now is delivery speed.
I mean honestly your prints might be better than the ones that some people are able to do, so as long as you keep yours high quality, I would imagine it might be easier for people to just buy yours
Well this didnāt take long. @Skunk sent me Surfrodz TKP and RKP trucks. Good news is that TKP is super easy because of the uniform hanger. Unfortunately, RKP hanger is much bigger and therefore the arm plate I make with the 24mm hole does not fit at all on the hanger anywhere.
I might be able to do RKP but it would require a big design change and could not use any of the arm brackets that I make as of now. The price would have to reflect this, with a single mount costing $35. Still not bad considering the trucks alone cost over $100 new.
Just got mine yesterday
But the provided 325mm belt didnāt really play well with my 97mm wheelsā¦the tensioner bearings are touching the inside wall of the wheelsā¦
Using my own 305mm belts nowā¦
@Boardnamics Kevin, just wanted to make sure did it have it put up correctly?
Is the 97mm wheels not possible to be tighten without having the tensioner bearings touching the wheel?
