Alrighty, done designing the pulley cover for the 63mm version. Here it is:
I will be selling these as an additional upgrade for $3.99. They will be printed in Black PETG for durability. Wall thickness is 3mm all around.
There will be 2 sizes to account for different wheel diameters. This is the small size. (for 90mm and below). There will be medium(90mm-100mm) and a large(100mm-110mm).
Another day. Some of the 63mm arms I cut have minor scratches but I am sending them anyways because I think people are tired of waiting.
I am getting new endmills from a friend which should really help things speed along. I do these in 100 part batches. The next time I get my aluminum, I hope to have all 100 mounts done in under a week.
I want to come to a point where I have them already packeged and ready before someone even orders. If that were the case, I could have them from payment to your door in 4 days anywhere in the US.
Can you send a picture of the scratches? Some of the scratches are âbuilt inâ the because the barstock theyâre cut from comes with scratches. Itâs the way everybody receives them. itâs sort of luck whether or not the barstock I receive is very scratched.
I can remedy this by wire wheeling them which I didnât forget the chamfer update. Doing both chamfer and wirewheel takes a lot of time however, so there would have to be a slight price increase.
Also, Iâll gladly send another one to make up for the mistake.
I will soon. I need to adjust them. The version thatâs pictured in this thread hastoo much overhang for my taste. I want them to print without supports.
Nothing wrong with TB trucks. You want a tight fit. Having to file a little bit is better than it being loose AT ALL.
Most of these clamps are designed to fit too tight, and you file a tiny bit to make it perfect. Cast trucks are never precisely all the same dimensions.
