Just made some samples of 14T 15T 16T 18T steel pulley with keyway(4mm wide).
as I checked, the 16T and 18T are OK,
but the 14T and 15T, because they are thin, after made keyway, there’s not much space left for the set screw. So, I decide to sell 14T,15T steel pulley without keyway later.
When it becomes available, I’ll buy a 14t without keyway
So only 10mm bore? Can you do 8mm? Can you do 20mm wide?
I’m in for steel 18T 8mm bore if you can source them
@Eboostin, 8mm bore need to wait later,for the moment, they don’t have the tools to make it yet. but I can make 8mm pulley with out keyway now, but people here seems more like it with keyway…
I already have them arranged, will got the 14T pulley within 3 days.
same i’d like to se 8mm bore on a 20t pulley
anyway can you make a 3mm keyway? or if you can make a 3mm to 4mm key
8mm would be nice!
10mm bore with 3mm keyway for APS
yes, I still have
18t steel with Keyway 8mm bore🙋🏽♂️
Yup thats what I want
Any updates?
18t-20t steel motor pulleys with keyway and 8mm bore for sure. Can’t find them anywhere!
15t steel 80mm bore with key ways ??
@dickyho Can you do a steel pulley - 10mm ID 18T 56m pitch for 20mm belt width with a 3mm keyway? Cheers
any idea when 18t-20t steel motor pulleys with keyway and 8mm bore will be available?
hard to find them
Agreed, especially steel
