yes, it can fit 15mm belt. 18T with 3mm keyway steel pulley, only have 1pc left now. need to wait a week to have another lot.
When you get them I’ll take 2!
Hey @dickyho I’m looking for some steel pulleys for 8mm shaft and15mm wide belt… Do you have any in stock?
Hi. yes, I have some here, what sizes of them you need?
2x 15 tooth and 2x 16
need later, 15T and 16T out of stock now.
I see. Do you have 14 and 18 instock?
I have 18 now. 14 no.
Ah okay. Any idea when you will have restocked them?
will have 15T , 16T within a week. 14T will 8mm bore 3mm keyway, still no plan to produce it.
Nice! I wait untill you have 15and 16 in stock… Thank you
@dickyho. Do these pulleys come with the actual keyway? Or is it only the pulley with a keyway slot?
they comes with the key.
that’s really good~~~ kind of a shame I assumed there was no keyway included and ordered some separately T_T
Any luck in getting 2 14t with 8mm bore with no key away?
have 14t with 8mm bore with no key away aluminum pulley
yes, I have 18T steel and aluminum pulleys, 10mm bore or 8mm bore.
Do the steel ones come with the keyway ? I mean does the “with keyway” mean that they have a hole called keyway or do they have a keyway hole and come with a keyway XD?
the 8mm bore steel pulley I have, they all have keyway(3mm).
